Apexi turbo timer on Supercharged S?
Old Apr 12, 2005 | 08:21 AM
Scorpion's Avatar
I could see using a timer on an SC...but only if you stay between 6-9k rpm for 3 hours at a time I'm not a fan of timers anyway, even on a turbo setup...you can save yourself a $100 just buy listening to the radio for a minute before shutting the car off.
Old Apr 12, 2005 | 10:34 AM
kane.s2k's Avatar
A lot of new alarms come with built in turbo timers. So I took two birds with one stone on that one and very cost effective...very.
Old Apr 12, 2005 | 03:04 PM
Slows2k's Avatar
Originally Posted by Doss,Apr 11 2005, 09:56 PM
what? The turbo doesn't spin with the engine off either.
You stated the turbo doesn't spin with the engine off, and it clearly does.
Old Apr 12, 2005 | 03:31 PM
kane.s2k's Avatar
It wasn't ever about the frictional heat from the turbine spinning. It's is so miniscule due to the oil and friction reducing additives that have bonded to the metal. The oil would sit on the bushing/bearing and the heat would just bake the oil which would leave a residue on it. Over time this constant build up of carbon and other products becomes significant and then the bearing/bushing cannot do its job properly. Thus it wears down on the center shaft and causes the turbine to wobble - considered to be a bad turbo at this point.
Old Apr 12, 2005 | 04:59 PM
Doss's Avatar
Originally Posted by Slows2k,Apr 11 2005, 05:39 PM
Since the SC isn't spinning with the engine off, there is no reason to use one.
You stated that the turbine spinning after the engine was turned off was the reason why a turbo timer is needed. Which is also incorrect. You had the right answer but wrong reason.
In theory even if the turbine stopped right when the engine turned off you would still need oil going threw it to cool it down it has nothing to do with the turbine spining.
Old Apr 12, 2005 | 05:42 PM
Vanos954's Avatar
It's kinda pointless unless you drive your car at 9000 rpms all the time and skid into a parking spot and shut the car off all the time for some reason. It's usually a good idea to let the car idle for a bit after hard runs but no real need for a timer. I had one on my Supercharged MR2 only cause I was so cool and had to be different Wouldn't say it's needed on an SC car though.
Old Apr 12, 2005 | 07:04 PM
kane.s2k's Avatar
It isn't needed at all on a S/C. It doesn't just get hot enough to be a critical problem.
"to be different"
Old Apr 12, 2005 | 07:31 PM
Slows2k's Avatar
Actually I said a SC is't spinning. We're splitting hairs at this point. I'm pretty sure we are both clear on why a turbo timer is used on a Turbo car, and why it's a waste on a SC'd one.
Old Apr 12, 2005 | 10:24 PM
Doss's Avatar
BallerONEdollar
Sep 15, 2014 08:30 AM
JerseyDude
Nov 1, 2007 07:46 AM
wilch
May 22, 2002 01:02 AM
