areomotive 340 pump install with relay
Old Aug 6, 2015 | 05:27 AM
  #41
Memo6453's Avatar
seems like 255lph on '06 or newer can get away with stock wiring. Walbro seems ok and im hoping my Deatschwerks 255lph works out. albeit on a s/c car.
Old Aug 6, 2015 | 10:04 AM
  #42
King Tut's Avatar
I ran the Full Blown 260 on my 2006 with stock wiring for multiple track weekends with no issues.
Old Sep 2, 2015 | 07:19 AM
  #43
Sideways's Avatar
Are you guys running the new wire back to the trunk on the passengers side or the drivers side?
Old Sep 2, 2015 | 07:43 AM
  #44
CoolGuy094's Avatar
I ran mine on the passenger side.
Old Sep 2, 2015 | 12:03 PM
  #45
Redline S2K's Avatar
Same
Old Sep 3, 2015 | 12:46 PM
  #46
King Tut's Avatar
I ran mine across the firewall in the engine bay and through the same grommet I had all my other wires run through and then down by the driver side door. I barely had enough wire and have the relay mounted just behind the driver seat.
Old Sep 6, 2015 | 11:59 PM
  #47
s2k manic's Avatar
passenger side all the way back relay on top of pump housing.then depined the stock connector and soldered in the 10 gauge wire tightened the bite put it back in the loom and she is still going strong 20k+miles just put 500 miles on it over the weekend and ran it down to 2 bars twice no trouble ever and it was 99 degrees outside. you cant run any of the stock wire not even 2 inches and you need to keep the idle fuel pressure in the 30's at least so in boost your using the highest volume the pump can supply after 60 psi or so volume drops significantly. there used to be a flow comparison chart of all the popular pumps it was an eye opener that's when i ditched the stock fpr and the walbro that was damaged from the initial comptech rrfpr and went full aeromotive340 pump and fpr just sayn
Old May 12, 2016 | 02:37 AM
  #48
s2k manic's Avatar
so a few more thousand miles and with the new supercharger setup at 14psi at 8500 rpm i am seeing 85% duty cycle definitely not going to try e85 with the areomotive but with just over 25000 miles on it things are good
Old May 13, 2016 | 06:44 AM
  #49
2004TurboS's Avatar
Is the aem fpr the best option for the stock replacement fpr?
Old May 13, 2016 | 07:38 AM
  #50
s2k manic's Avatar
i chose aeromotive due to higher flow and a pressure check port it will regulate down farther than an aem i do know that
lude9285
Apr 29, 2016 11:29 AM
EK9MAX
Sep 5, 2014 08:06 AM
ScienceofSpeed
May 14, 2014 04:49 PM
Forcedbird
Aug 30, 2013 06:05 AM
Jack_in_the_Box
May 26, 2012 09:28 PM
