asp pulley and belt for comptech sc kit
Old Jan 22, 2007 | 08:12 PM
dustinmallen's Avatar
Default asp pulley and belt for comptech sc kit
hey guys, i am new to the whole sc scene. i just recently bought a near complete used comptech kit. it is missing the crank pulley, but i was figuring on running a higher boost than stock anyhow.
do you guys suggest 9lbs or 7 lbs?
also, i keep hearing people talking about asp pulleys, but for some reason no matter what i google, i cannot find a site to purchase an asp pulley. also, will a normal belt from autozone work for this application, if so, do these belt numbers and pulley sizes for the boost seem accurate?
Stock pulley size: 4.30" (5.5psi) Belt: 4060400
4.25" (6psi) Belt: 4060395
4.00" (7psi) Belt: 4060390
3.75" (8psi) Belt: 4060390
3.50" (9psi) Belt: 4060385
thanks everyone, dustin.
Old Jan 22, 2007 | 08:28 PM
Enthralled's Avatar
PM kane.s2k,he can make you a custom pulley and get you a belt for it.
peace
Old Jan 22, 2007 | 08:30 PM
Sideways's Avatar
https://www.s2ki.com/forums/index.php?showtopic=254159
Old Jan 23, 2007 | 10:47 PM
CKit's Avatar
Crank pulley is different than boost pulley.
There's only one size on the crank pulley and you'll likely have to order a replacement from Comptech. The boost pulley will be directly attached to the snail.
Old Jan 24, 2007 | 07:06 PM
batikan's Avatar
peace
kane doesn't do custom pulleys himself. He sells the ASP Pulley.
PM him either ways though. HE can get you the right size pulley.
PS: def. 9lbs since it is going to cost the same. Why lower power
Old Jan 24, 2007 | 07:20 PM
Dsgs2k3's Avatar
^well it depends if he wants to buy an engine management system for the higher than 7lbs of boost.
Old Feb 4, 2007 | 03:13 PM
i plan on purchasing a vafc 2. if i choose to go to 9 lbs of boost on the ctsc, using a walbro 255lph and aem hi press fuel regulator, will the stock injectors suffice?
Old Feb 4, 2007 | 06:49 PM
ATOice's Avatar
I got my 3.5 asp pulley from a member on here, pushing a little more than 9.
Old Feb 4, 2007 | 07:26 PM
Sideways's Avatar
My experience was the stock injectors should be replaced above 300 rwhp.
s2kadrenalin
May 14, 2011 07:50 PM
jbell
Oct 30, 2008 09:00 PM
00S2K01S4
Aug 26, 2006 10:23 AM
