Back To Stock Questions
Old Mar 12, 2011 | 03:29 PM
dsddcd's Avatar
Default Back To Stock Questions
Got the car nearly back to stock but I am getting a few codes now. Can anyone remember the positions of the 02 sensors? I can remember if blue is the primary or the white one.
Old Mar 12, 2011 | 07:44 PM
Spoolin's Avatar
I believe the blue one is, but I cant remember for sure.
Old Mar 13, 2011 | 11:57 AM
o'malley_808's Avatar
Blue was for secondary. It is the longer of the two. Also the secondary (blue) is a female plug and the primary is a male plug so they cannot be interchanged.
Old Mar 13, 2011 | 05:31 PM
TRBOKEV's Avatar
You couldnt figure this out?
I still got to put my vacuum lines behind the air box back to stock... I have the stock lines but no clue as to how they go..
Old Mar 13, 2011 | 05:58 PM
dsddcd's Avatar
You got it, this is what I thought at first but I saw several other posts with the blue as the primary. After getting a Low Catalyst Efficiency and O2 Sensor Response Error I figured out I had them reversed.
Yeah, tell me about it, first off it has been years since I used both, second the Honda Service manual really sucks compared to most manufactures, third I relied on posts here that obviously had them wrong.
As for the Vacuum lines that was really easy, I used the Greddy manual to get this one figured out.
Manifold to check valve
Check Valve to Vacuum Canister
Vacuum to Solenoid
Solenoid to SAIV (Secondary Air Injection Valve)
dsddcd
Mar 13, 2011 07:41 AM
dsddcd
Mar 12, 2011 09:03 PM
blurnj13
Dec 14, 2006 07:46 AM
