s2000
Old Mar 13, 2011 | 03:16 PM
Manus2kpr's Avatar
Default s2000
Hi guys i am thinking of doing my s2k turbocharge but i have many questios because i am new in this thing about f series turbo so first thing thath i want to know is how many whp can handle the s2000 engine with stock internals, stock rear end and if the transmission can handle ++++ hp ??? thanks
Old Mar 13, 2011 | 03:42 PM
seoul2k's Avatar
you should just read up and do some research this topic has been covered 100s of times... its all in the tune. if you get a 3mm ilp hg and arp head studs there have been people that have gotten 700+ out of their set ups and there have been people to get 400 on a stock motor. im shooting for 330 on my stock motor because that is what my goals are.
only advice is to make you have at least 2000 for tuning and misc bs that can happen. i forget who said this but they said have 4000 for the kit and another 4000 for tuning and misc stuff to be safe. you'll need to upgrade your clutch and pp, diff, and other stuff if your trying to push some serious power.
Old Mar 13, 2011 | 04:29 PM
o'malley_808's Avatar
You don't need a 3mm HG or ARP head studs to make 700+ on the stock block. I think both of you should revisit the FAQ and member power chart
Old Mar 13, 2011 | 05:16 PM
seoul2k's Avatar
Never really looked into making over 400+ but from what i've read you need to lower your compression to get that much power out of our cars safely. All the people i've talked to that make gobs of power run 3mm head gaskets and a lot of people that throw pistons into their motors to lower the compression end up running the stock hg. I guess the 3mm hg is a cheaper way to lower your compression, but i havent found someone running on a completely stock motor making 700+ hp and hasn't blown it up within a couple of weeks...
Old Mar 13, 2011 | 05:30 PM
3en's Avatar
3en
You need to visit the power list in the stickies. I believe there are 2 s2ks listed there that made over 700hp
Old Mar 13, 2011 | 08:20 PM
seoul2k's Avatar
i have never really looked at it hard tho just skimmed over it... i wonder how long their motors lasted tho not trying to be a smart ass or anything just saying.
Old Mar 13, 2011 | 08:22 PM
passmans2kny's Avatar
whatever u do, don't do the 3mm head gasket
Old Mar 13, 2011 | 09:16 PM
3en's Avatar
3en
Great manifold design+correctley matched turbo+great tuner+right fuel= safe high horsepower build
The easier air can flow the less heat and more power can be made with the right fuel(e85,100 octane, q/c16, or water meth)
Turbo2000s2000
Sep 22, 2016 10:55 AM
OHclassic
Sep 16, 2012 06:46 AM
SilverStreak476
May 22, 2012 11:04 AM
AWWHITE s2k
Feb 8, 2012 08:03 AM
redx
Jan 5, 2011 11:07 AM
