Base Map
Old Aug 1, 2008 | 10:06 AM
03silver2000's Avatar
Default Base Map
I am almost done with my turbo install, and I am going to need a base map to drive it around for a few weeks before I get it tuned, I want to make sure any little boost leaks or whatever will be worked out before my tune.
My set up is going to be:
Aem Ems 1052u
3mm cometic headgasket
precision 880cc injectors
omnipower 4 bar map sensor( I know the parameters to enter into the ecu for this)
60-1 turbo .63ar
3 inch intercooler piping
hks ssqv bov
tial 38mm wastegate
walbro 255 fuel pump
hp performance manifold
hp performance downpipe
my email address is gosettij3@yahoo.com
umm. I think that should be enough if I remember anything else Il put it up, If someone can send me a basemap
thanks Jordan
Old Aug 1, 2008 | 03:19 PM
I also have an ap1
Old Aug 2, 2008 | 08:57 PM
okay, I started her up with the stock ecu tonight but I need a base map or somebodys map to be able to start her with my aem and boost it, someone please help!!!!
Jordan
Old Aug 2, 2008 | 09:53 PM
pleaseee someone help me!!!1
Old Aug 3, 2008 | 09:58 AM
ok, I started my car last night with the stock ecu cause I need a basemap on my aem ems 1052u to use that, so far so good one tiny oil leak coming from the oil feed going to the turbo, I just took care of that right now and one injector is leaking a little but thats because the fuel rail needs to be tightened just a little bit more. I dont have a downpipe made yet and I dont have my intercooler piping on, waiting on those things than I should be good to go.!!!!
She sounds great running again!
Jordan
Old Aug 3, 2008 | 12:10 PM
SPECIAL-OPS-S2K's Avatar
it started and ran with 880cc injectors running off of the stock ECU fuel map? I would have thought it would be PIG RICH since the stock computer thinks its injectors are MUCH smaller.
Old Aug 4, 2008 | 09:49 PM
yah, started and ran off of stock ecu but I need a map to jus get it going to make sure everything is worked out before my tune!
Old Aug 5, 2008 | 07:59 AM
si2die4's Avatar
Make your own from scratch bro. Take the AEM stock map and modify it for the injectors and boost.
Old Aug 5, 2008 | 09:12 AM
passmans2kny's Avatar
call your tuner, he should supply you with a base map
Old Aug 7, 2008 | 02:42 PM
D1sclaimer's Avatar
No more nitrous?
Have fun with your turbo. Please post your dyno graph after you get tuned.
