Base map for Turbo kit
Old Dec 20, 2012 | 05:16 AM
o'malley_808's Avatar
Originally Posted by J-GO
My car made 720 hp at 31psi on a 3mm head gasket. Only used it for 3,000 miles but it never blew a head gasket.
I think you are just nearing the expiry date for the gasket. Most pop between 3000-5000miles
Old Dec 20, 2012 | 12:58 PM
Reapur's Avatar
So why can't you just tow the car to the tuner and get it on the dyno with the new clutch? I don't see why it needs to be broken in, you're not banging gears on a dyno, you're pulling a single gear.
Old Dec 20, 2012 | 04:03 PM
dsddcd's Avatar
If you'd like to get a map you might want to list what type of EMS and more details on the car
As for the head gasket it may not be optimal but it certainly
does work.
Old Dec 21, 2012 | 12:17 AM
Reapur's Avatar
does work.
He said he has AEM ems series 1
Old Dec 29, 2012 | 04:17 PM
jdms2000f20c's Avatar
Well I was only needing the map for the 500 mile break in for the new clutch. Will pulling a single gear not break it. If I can get it tune like that then I'll break it in after the tune.
Old Dec 29, 2012 | 05:01 PM
Reapur's Avatar
Tow car to tuner.... break in clutch on the way home.
Old Dec 29, 2012 | 09:11 PM
I'll do that thanks
Old Dec 30, 2012 | 10:35 PM
miguel329's Avatar
Thats how i did mine no issues.
Old Dec 31, 2012 | 06:27 AM
bois2k's Avatar
I drove around with my turbo kit inline pro stage 2 on stock ecu/injectors just to break the motor in and make sure kit was installed right and nothing was leaking just never went into boost I don't believe a clutch even needs a break in ha
titoracingfab
Jan 22, 2013 12:51 PM
Enthralled
38
Jul 5, 2009 09:21 AM
scottieboy561
Nov 7, 2008 06:31 AM
sbrodacz
Sep 12, 2008 06:58 PM
kleecker
Aug 9, 2006 02:32 AM
