On Batteries
Old Oct 5, 2013 | 09:08 PM
bgioan's Avatar
Perfect time for me too!! My current battery is dead and my car will start only if jumped, not even charged. I am also just about to install my turbo
Old Oct 7, 2013 | 07:27 AM
Redline S2K's Avatar
I've been doing alot of research on lithium batteries. Found some good info on Shorai,Ballistic (battery I plan on using) and Murai on the Lotus, R1/R6, and Miata forums. Also a little on the Porsche forums as some of those come with factory lithium batteries. I've found that a lot of the cases of lithiums dying is do to high parasitic draw and loads. I did a draw test on my car and after all the ecu's and electronics go to sleep (power down) my car fluctuates from .008 and .007 milliamps which is great for a car. You don't want more than 20-50 milliamps. A draw like that shouldn't kill the deka or lithium battery on a daily driver. For wires, any 0guage from a car stereo shop will work fine. I ordered mine from Knukoncepts on amazon for like 1.80 a foot. If relocating to the trunk, I'd use 0 or 0/1 like Timg said.
Old Oct 7, 2013 | 09:10 AM
Soul Coughing's Avatar
Great information. I've been researching Lithium Ion batteries as well and may make the jump in a year or two. I moved to 0 gauge wiring for my battery relocation in the trunk, also buying from Knuconcepts, and found the car started faster than my 4 gauge wired battery under the hood!
Old Oct 7, 2013 | 09:39 AM
spectacle's Avatar
I cosign everything stated in this thread.
I have an Odyssey style battery mounted in the trunk and it will not survive more than a few days without a charger or a start. I barely drive my car so I keep it on a trickle charger. Cold starts aren't a problem but warm starts are hit and miss sometimes. If I had to do it all over again, I would do a stock style replacement battery in the spare tool well with 0/1 gauge wiring.
Old Oct 7, 2013 | 09:40 AM
spectacle's Avatar
Oh and anything but an Optima those batteries are absolute junk.
Old Oct 7, 2013 | 09:52 AM
camuman's Avatar
I had good use of a 34/78 yellow top. Survived 6 years in Florida heat and barely being driven. Last 6 months it would finally die if left for over a week or so.
Old Oct 7, 2013 | 12:51 PM
I bought my s2k used and it had an optima. It left me stranded twice before just dying. I cut the car off at home and it wouldn't start again. No lights, no crank, nothing.
Sent from my SPH-L720 using Tapatalk 4
Old Oct 7, 2013 | 12:53 PM
spectacle's Avatar
JUNK
Old Oct 7, 2013 | 03:39 PM
rrounds's Avatar
Do you have to "warm up" the battery to start your car when it's cold?
On my bike I run the LFX18A1-BS12 and when it gets cold(under 30*F) I have to turn on my high beam for a min. to warm up the battery. Then my bike starts right up even when the temps are in the teen's. Lots of power out of such a small sized battery(2.3 lbs, 270 CCA), best battery I've ever had in my bike.
ROD
Old Oct 7, 2013 | 03:56 PM
takchi's Avatar
Been using Shorai battery for a year with about 16-17k miles on it already in various conditions ranging from 25ºF to 115ºF and in heavy downpour. Car not run for 2-3 weeks and car still starts up fine. Have used this battery to crank over SC kit with 1000cc injectors and 8lb flywheel no issues as well.
