Battery relo to trunk
Old Sep 21, 2014 | 05:39 AM
camuman's Avatar
Default Battery relo to trunk
i did this years ago and use a big ass fuse on the main line to the front. I want to swap it for a resettable breaker. What does everyone use?
I carry extra fuses just in case but figure a breaker is the better way to do it.
Old Sep 21, 2014 | 05:54 AM
grubinski's Avatar
Given the availability of a 5# battery that functions fine in our vehicles (Shorai) ... I'd just put one of those in the stock location. You'd pull a LOT of weight out of your car. The stock battery, and the big cables to get to the engine bay from the trunk ... and regain trunk space.
I've gone to the trouble of moving the battery into the trunk of a lot of my previous vehicles, for all of the obvious reasons, but I've got a Shorai in the S2K for 6 months now, and it works fine.
Old Sep 21, 2014 | 06:17 AM
camuman's Avatar
I already have it relocated for the last few years with zero issues. Can't put the battery you reference up front cause a giant divided side winder turbo manifold, down pipe, and other crap is in the way . I am far from concerned about a 20 lb battery sitting in my trunk when I trap over 120 in the qtr
Old Sep 21, 2014 | 06:41 AM
DaGou's Avatar
boost takes your car off of a diet! My battery is in the trunk to and put big ass fusible link right at the battery terminal. Carry one spare but over a year so far so good. If it ain't broke do not fix it!
Old Sep 21, 2014 | 11:01 AM
S2K-F8's Avatar
This is what I use:
Fosgate
I have the 200amp one, mounted very close to the battery on the negative side. Easy way to kill 12v power when working on the car. Been setup this way for 4 years, no issues
Old Sep 21, 2014 | 05:11 PM
staylor725's Avatar
I'm Doing the same 200amp breaker switch a about 1ft away from the battery
Old Sep 22, 2014 | 04:09 AM
Redline S2K's Avatar
I'm using a 150 amp breaker from Stinger Audio
http://www.sonicelectronix.com/item_..._I-hoC_8rw_wcB
Old Sep 22, 2014 | 07:04 AM
Kermdaddy's Avatar
I use the Stinger audio one as well.
Old Sep 22, 2014 | 05:15 PM
illestrolla's Avatar
I forget what I have at this point it's stuffed in my build thread somewhere, but Breaker>Fuse 100x over IMO
nguyen365
Mar 26, 2018 08:42 AM
6262
Apr 2, 2014 07:26 AM
6262
Mar 27, 2014 09:54 AM
fperra
Nov 27, 2004 05:36 PM
