baZurk's boost build
What port is everyone using to feed wires into the car? I am trying to yes the one between the brake booster and the fender wall but I can't even remove it. I'm incredibly frustrated with the thing now.
I cut a small hole (well, punctured is a better way to state it lol) in the grommet on the firewall to run a few of my harnesses. The others run through a grommet on the firewall where my cruise control cable used to reside.
Yeah I use the one that's below/beside the brake booster that has the harness running through it already. I had better luck with feeding the wire through from the inside, but you have to wedge your body up under the dash, lol. I "punctured" the grommet as well to run my wires.
and it helps to have good friends who's time can be bought with beer
looking good. i hope you have a turbo blanket
what size spring is in your wastegate?
also.. i don't want to shit on your parade but i had the exact same oil feed as you and it looks like your hood will not clear .. mine would close and latch but it would push up right there. i had to change my fitings for the turbo from a straight fitting to a 90 fitting and then use the straight end of the hose on that side.
In for numbers. I bet you surpass your 400whp goal
