baZurk's boost build
Old Mar 11, 2014 | 04:40 AM
  #281
herecomesboost's Avatar
Originally Posted by DaGou
Is there a thread somewhere that explains the two step module, where to get one, and how to set it up?
Which software are you running? 2step can be thought of as a soft limiter; meaning below a predefined MPH, you can have the throttle fully opened (foot to the floor) while maintaining a specific RPM. 2step helps to launch consistently.
Regarding wheel hop, I suggest loading the rear suspension before you launch (engage the e-brake and let off of the clutch slightly).
Old Mar 11, 2014 | 05:18 AM
  #282
Redline S2K's Avatar
What tires are you using and what psi were they at? Maybe look into solid diff mounts or diff mount collars.
Old Mar 11, 2014 | 08:02 AM
  #283
baZurk's Avatar
I tried to pre load when I went up to the line I guess I missed that up hahaha
Noted about the diff mounts. Some stiffer ones would be nice. Is there an oem axle replacement that is worth getting? I'm not trying to break the bank I just want an OEM+ rearend
Tires were Hankook v12's at 30 ish psi
Old Mar 11, 2014 | 08:15 AM
  #284
Try a little less tire pressure, I would run about 27 in my srt4 when I tracked it. V
Old Mar 11, 2014 | 08:24 AM
  #285
DaGou's Avatar
Thanks I have an 06 so Hondata. So at zero MPH I can put my foot to the floor and have whatever RPM I set?
Old Mar 11, 2014 | 08:47 AM
  #286
baZurk's Avatar
Originally Posted by herecomesboost' timestamp='1394541614' post='23056684
[quote name='DaGou' timestamp='1394540538' post='23056672']
[/quote]
Hondata has the two step option but it does not have ignition cut (anti-lag), only the soft limiter.
Old Mar 11, 2014 | 10:58 AM
  #287
DaGou's Avatar
Originally Posted by baZurk
Originally Posted by DaGou' timestamp='1394555087' post='23057128
[quote name='herecomesboost' timestamp='1394541614' post='23056684']
[/quote]
[/quote]
You guys are just a wealth of info today! One more stupid question now that I know what a two step is... what is a soft limiter, I google it but got a lot of audio terms...
Old Mar 11, 2014 | 11:42 AM
  #288
SlowTeg's Avatar
Wheel hop is a b*tch and having larger wheels/lower profile tires makes it worse. Best thing is to lower tire pressure a lot. I'd try 25 max or even less. Of course getting tires with softer sidewalls is good but that isn't always an option.
I'd be too big of a puss to try and drag race my s2k. Seems like any serious wheel hop and these diffs are toast.
Old Mar 11, 2014 | 01:28 PM
  #289
d-bo's Avatar
YO! I have brand new innovative diff mounts. PM me if you would like to purchase them
Old Mar 11, 2014 | 09:03 PM
  #290
benes2k's Avatar
+1 on the solid mounts. they help more than anything with wheel hop.
