BaZurk's Shaved bay/ build thread
Old Jan 24, 2015 | 04:17 PM
  #71
baZurk's Avatar
Fan setup will be two high performance spal fans on relays. Should flow well over 2000cfm. Also, plans are in for a mishimoto oil cooler with t-stat mounted behind the passenger side faux brake duct
Old Jan 25, 2015 | 08:07 PM
  #72
9KRPM2.0's Avatar
Bazurk.... I love the time and attention to detail you guys are putting in this car. badass!
Old Jan 26, 2015 | 04:39 AM
  #73
baZurk's Avatar
Thanks!
Old Jan 26, 2015 | 12:34 PM
  #74
Sideways's Avatar
Originally Posted by baZurk
Radiator core came in today...... along with the new throttle body. This is skunk2's new 74mm. So far it looks great. Got it from Nick Devlin. Arrived in about 24 hours after payment was sent. Great person to work with!
Very impressive setup you are building. I ended up with the Skunk II TB also.
At 74mm, it absolutely maximizes the manifold and leaves very little for sealing.
Old Jan 27, 2015 | 05:09 AM
  #75
baZurk's Avatar
Thanks!! Did skunk2 supply you a gasket or did you use an oem gasket and modify it?
Old Jan 27, 2015 | 06:17 PM
  #76
wy2slow_z's Avatar
Originally Posted by Sideways' timestamp='1422308049' post='23482279
[quote name='baZurk' timestamp='1421956075' post='23477820']
[/quote]
it came with a new ggasket. I haven't mounted it yet though
Old Jan 28, 2015 | 10:47 AM
  #77
herecomesboost's Avatar
Nice! Does that version delete the water line to the TB? Map sensor on the bottom is certainly cleaner (from an aesthetics standpoint) imo
Old Jan 28, 2015 | 10:50 AM
  #78
baZurk's Avatar
I would imagine so. I actually haven't seen the TB in person yet. Having the map sensor on the bottom will be nice and make it easy to pull the whole injector harness and sensor clips under the intake manifold.
Old Jan 28, 2015 | 04:36 PM
  #79
wy2slow_z's Avatar
i think its going to make it tight under the TB. pulley housing makes the area quite tight.
Old Jan 28, 2015 | 04:52 PM
  #80
kryptonite's Avatar
Member
Spotter
Subscribed. Looks like its going to turn out to be a solid build
