BDL throttle body stickyness
Old Aug 25, 2007 | 05:38 PM
abv's Avatar
abv
Default BDL throttle body stickyness
I just got the bdl throttle body (70mm). When you get them there is the option of single or double wind on the spring. I selected single wind for better throttle modulation.
So I get it and it sticks. Switch it to a double wind... still sticks.
Return it to BDL (great customer service by the way really good guys over there) they check it over reassemble it and send it back to me.... (Single wind) Still sticks.
I send it back and they send me a brand new one. Set for single wind. Sticks worse than the first one.
I set it for double wind and also try to clean it up a bit (remove burrs etc.) still sticks.... Am I having serious bad luck here or have other people experienced this?
My cable is fine. I have never had any issue with my stock throttle body. I think the culprit is in the return spring. Everything else seems fine it moves freely until I put the spring on it and try to run the car with it.
P.S. The stickiness is happening at initial throttle opening. Sticks at around 3000rpm
Thanks in advance for help / suggestions
Old Aug 25, 2007 | 06:10 PM
squirrels2k's Avatar
are you using just the factory gasket for the tps sensor ? that was my problem with it sticking. i made another gasket and doubled the thickness. works great now. it was the tps sensor pushing on it that caused it to stick open.
Old Aug 25, 2007 | 07:50 PM
abv's Avatar
abv
I'll give that a try. Do yo know if your single or double wound on the spring?
Old Aug 25, 2007 | 08:16 PM
abv's Avatar
abv
allrighty tried that ....not it...still sticks...this is frustrating...any other ideas?
Old Aug 25, 2007 | 09:19 PM
abv's Avatar
abv
allright new update...It only sticks when the car is running. Works fine when either not running or off the car...
Old Aug 25, 2007 | 09:36 PM
GDM S2K's Avatar
mine has Zero issues
Old Aug 25, 2007 | 11:33 PM
thats strange. dont know which mine is but i haven't had any other problems with sticking. best of luck with it.
Old Aug 26, 2007 | 09:56 AM
abv's Avatar
abv
So I have the stock (comptech) bov which goes right back into preboost intake. Same for the front of the valve cover line. I removed both of those from pre boost. Seems to help. Not 100% cleared up but better. Aftermarket bov? would that help?
Old Aug 27, 2007 | 08:13 AM
abv's Avatar
abv
any ideas whay this may be happening? and for who ever is running the bdl TB are you running single or double wind?
Old Aug 28, 2007 | 08:24 AM
abv's Avatar
abv
anyone? any Ideas?
And is everyone running the double or single wind?
thanks
