Bearings for rebuild
Old Sep 8, 2011 | 07:19 AM
Sideways's Avatar
Default Bearings for rebuild
Several owners have asked about what bearings I used in rebuilding my Vortech.
The low speed side was originally a 6205-C3, an ABEC-1 rated buck a set skate board wheel bearings.
The max rating was 15,000 rpm and I was spinning my input over 17,000 rpm.
I upgraded to a couple of 6205P5 by FAG, manufactured in Germany.
An ABEC-5 rated bearing with slightly increased load carrying ability and a max input shaft speed of 25,000.
This upgrade was less than $100.
On the high speed side I sourced a matched set of ABEC-9 SKF bearings made in Italy. 7003 DC/P4A DGA
I got these on ebay. They run $420+ a set retail but can be had for less. I avoid Chinese bearings.
For seals, 928motorsports has a good set for $67 shipped.
HTH
Old Sep 8, 2011 | 09:28 AM
s2000Junky's Avatar
Damn! well you get what you pay for in this regard I guess.
Old Nov 26, 2011 | 05:47 PM
Road racer's Avatar
Have you considered ceramic bearings? I run these in 2 cycle kart engines and axle bearings and seen increases in RPM's & mph and no failures. Our engines typically run 15,000 rpms. In a SC application with high rpm's & heat, I would think ceramic bearings would be the way to go. I did a lot of research on this in the past for karting & it makes sense.
Old Dec 1, 2011 | 08:11 AM
Sideways's Avatar
Ceramic bearings are the best. I'm looking into putting them in my fishing reels.......$$$ No rust. I fish for tuna.
Old Dec 1, 2011 | 08:50 AM
Moddiction's Avatar
Former Sponsor
I plan to rebuild/upgrade my vortech blower over the winter. Hopefully can get some more flow out of it!
fltsfshr
Aug 14, 2009 10:32 AM
JoeyBalls
Aug 29, 2008 06:08 PM
purehonda
Feb 5, 2007 04:37 AM
BlueS2000Boy
Nov 18, 2003 06:18 PM
johnyx22
Nov 19, 2002 11:56 AM
