Beating the Heat!
If you want to use it for safety and primarily to cool IAT, you run it in a single port pre TB config with a higher % of water. If you want to use it for maximizing your power output, you run multi port config. Or if you want to go big and completely functional, run both configs as a two stage system. typically pre TB first and multi port in the second stage. Doesn't matter what your boost level/hp is, just size your nozzles and % of water/meth accordingly
Originally Posted by camuman' timestamp='1311550486' post='20810961
Water injection. It works. U hit boost, it sprays and cools everything in it's path.
I was considering this or meth, but SoS and UMS STRONGLY advised me against this route.
Yes, I covered most of the AC with heat tape and the amount of heat soak and the time it takes IATs to drop have improved. The bare aliminum aftercooler of the CT kit is a heat soak whore.
Sent from my iPad2 using Tapatalk
Originally Posted by Kyushin' timestamp='1311562080' post='20811316
[quote name='camuman' timestamp='1311550486' post='20810961']
[/quote]
Ya, 1000 things goin on around here too...
They honestly didnt give much reasoning behind it besides sayin that it isnt a reliable route for a DD.
Originally Posted by siadam' timestamp='1311563491' post='20811371
[quote name='Kyushin' timestamp='1311562080' post='20811316']
[/quote]
[/quote]
Typical response... usually from those that haven't actually DD it. I stand by what I said.
[/quote]
[/quote]
If you try to run an aggressive tune that relies on the injection then yeah that's stupid for a DD. On the other hand if you just spray alittle and keep the tune in check, then you get the benefit of low charge temp (mine are never above 98F) and lower exhaust temp. I've used it for >2 years on my DD.
[/quote]
Originally Posted by Kyushin' timestamp='1311574715' post='20811721
[quote name='siadam' timestamp='1311563491' post='20811371']
[/quote]
[/quote]
[/quote]
Agreed.
