Beating the Heat!
I beleive they sell two different flow rates for 3/4in hose. I remember SOS selling a larger one in the beginning, and a smaller one to me a year later after they started selling the kit. I had two at one time, so I just kept the higher flowing pump, and sold the lower flowing one.
Negative ghost rider! The pump worked when I put the fan on, it was a fluke I guess... turned out to bethe relay. Just switched the relay, it took the new one a minute to click on but then all was fine.
While im in the garage, I usually listen for the pump when I key the ignition on but before I left to meet a gal lastnight I got pissy when I noticed the sound wasnt there. Messed around with it some then changed the relay and problem solved!
I believe is the SoS upgraded pump, it was so long ago when I installed their heat exchanger. I wanted to go larger with the pump but afew people said not to as it would decrease cooling efficiency by not giving the water enough dwell time in the radiator.
