Belt not on the pulley properly.. Pic attached
Hi guys,
The install is almost done. The belt isn't sitting right on the pulley though. When I put the pulley on the shaft I noticed there was about 5mm left between the pulley and the Base of the SC.. I thought it would sort it's self out. The pulley will not go further down the shaft though, I may need to press it somehow.. Does anyone have any ideas?
Could I space the supercharger outwards by putting washers being the bushes?
I also haven't installed the ESM yet but haven't been driving above 3000rpm to a friend's garage, will this be a problem?
Thanks guys.
So today I put about 0.5cm of spaces behind the bushes to bring the pulley out from the block. When i cranked it over though the belt went to the exact same place again! I can't make sense of it.. I've also flipped the belt and you can see that it's not sat on the tensioner properly and has scored by belt in both directions. Can anyone spot anything wrong?
I was assured this pulley was for the N1000
Cheers.
Cheers.
Hi,
The belt snaps back to the same position with or without the spacers. I have taken the spacers off now and it's still the same. The SC pulley doesn't have a guide for some reason. But it should still align tight? Is my pulley the right way around? Does the crank pulley look OK?
