Best exhaust system for Supercharged 2.2
I have a CT, and get 306HP in 95F heat on stock SOS boost. An exhaust will drop your boost (i max 5psi), but that's not a bad thing. If it drops your boost, that means more air is going into the motor, all else equal.
The CT won't make the absolute most power, but it won't be obnoxious, either. I found the Invidia obnoxious.
Definitely stay away from the Invidia exhaust and skunk2, Megan and the like if not wanting a loud bassy exhaust.
I'd say for now do a test pipe first and then look into one of the nicer 70mm exhausts. Worth the extra money for a really nice sounding non obnoxious exhaust imo.
Ditto
I have gone from stock exhaust to an Amuse R1000 (single 70mm header back)to my current T1r 70r em Dual sparrow 70mm and have never notices a drop in boost, and that was non aftercooled. Even after I installed the Aftercooler a few weeks ago, I noticed no significant drop in boost. So if it drops your boost more air is going into the engine and that's better?
so if it drops it to 1psi that's good? I don't fully understand what ur saying.To the OP, a 70 or 76mm single will give you some good gains but will be loud. If you want to get the most HP of of an exhaust go with those, the straighter the better, bends will cause more back pressure.
"The Best" is going to give u many opinions and you will still be left to make ur own choice. For me, the Asura and T1R are two of the best duals for the S, both making some great power, and both sound nice not rice lol. If you have a good amount of S owners around you, I highly suggest you see and hear what they have, go on some ride alongs. Videos do not do exhaust justice, but when I get a chance I will take one of mine. Good luck
Free flowing exhausts will lower the boost with a supercharger by freeing it up. That is why some larger exhausts people have seen a loss in power. If you bump it back up to the same psi there will be a nice gain from the new exhaust.
What do you mean an exhaust will drop your boost? I don't see how an exhaust has anything to do with the amount of air the blower is pushing to the intake manifold.
so if it drops it to 1psi that's good? I don't fully understand what ur saying.http://en.wikipedia.org/wiki/Ideal_gas_law
An aftercooler would lower boost because it removes heat...you have to balance the other side of the ideal gas equation, so pressure drops.
You are less likely to lose pressure with a turbo, as the impeller speed is not locked to engine speed. Also, the amount of pressure after the impeller will have an effect on how much air the impeller can flow. So, there are 2 vectors...the removal of restriction decreases air volume and pressure in the manifold, BUT the removal of pressure would allow the impeller to "squeeze" a little more air in, especially if impeller speed is variable. The net effect of the change could be large or even a wash depending on many factors.
Also, adding a large exhaust may enable more airflow, BUT an engine needs some backpressure, so you may lose power by over-doing it...and you should still lose boost.
It's just not a well-known concept that boost and power are always positively related. At its fundamental level, boost pressure in the manifold is how much is NOT going into the engine. You can remove pressure, and still make more power. Restore that lost pressure, and you will likely make EVEN MORE power, though.
Thanks Moddiction, you probably put in a better explanation than I did. I'm on a stage 1 SOS kit, so I may not have the option to "restore" the boost since I may not have the fuel headroom.
lol
