Best Ring/Pinion and LSD for 8.8 Diff?
Old Apr 10, 2013 | 09:56 PM
Irishflame27's Avatar
Default Best Ring/Pinion and LSD for 8.8 Diff?
Hey guys,
I just picked up a Thunderbird 8.8 diff and I'm looking to build it and get it ready for my next s2000. From the reading ive been doing it seems everyone is really liking the 3.90 ring/pinion setup, but what LSD is everyone using? Id like something streetable (one that dosent whine during driving or bark around every corner), but can handle 700-800 whp.
Please point me in the right direction with your suggestions on gears and LSD options!
Thanks so much for the help!
Old Apr 10, 2013 | 10:09 PM
redboost10's Avatar
you cant go wrong with richmond gears. As far as the the posi goes, the stock one is fairly strong. we have been single digits (low 9's in a heavy mustang) on a stock posi.
Old Apr 11, 2013 | 05:25 AM
bobbyrandolph440's Avatar
What ever one u go with make sure and go 31spline there great and the other guy said the stock newer LSD are super strong
Sent from my DROID RAZR using Tapatalk 2
Old Apr 11, 2013 | 07:42 AM
passmans2kny's Avatar
i did the eaton posi with 3.9 richmond gear, no complaints
Old Apr 11, 2013 | 08:25 AM
1SlowSi's Avatar
You need the 28 spline not the 31 if you're using the full blown kit. I went with the trac-loc LsD which all of the mustang cobras use without any issues. It's more streetable than using an Eaton diff but if its strictly a drag car then use it. If you go with trak-loc or true trac etc, you can do a simple mod of adding in another clutch disc to the entire clutch pack to make it hold more power. Read the mustang forums. I went with Motive 3.90's. there shouldn't be any gear noise if set up properly.
Old Apr 11, 2013 | 08:44 AM
oh i should add the richmond gear whines on mine, a few mustang guys said go ford racing or motive bc they r quiet
Old Apr 11, 2013 | 11:08 AM
Ford racing are the best
Old Apr 11, 2013 | 11:54 AM
1SlowSi's Avatar
Ford racing is the best but they don't make the 3.90. I say if you're less than 600hp stay with 4.10s and above go 3.90 richmond/motive or 3.73 Ford Racing.
Old Apr 11, 2013 | 12:16 PM
i was told ford racing and motive come from the same place, and motive makes a 3.9, go with the motive
Old Apr 11, 2013 | 02:49 PM
thanks alot guys!
Anyone running a different front cover?
