Blockguard?
Old Jun 18, 2006 | 08:30 AM
Deathscythe's Avatar
Default Blockguard?
I found this one on Ebay F20C Blockguard . has anyone tried using this? I emailed the shop and they have one for F20c.
Old Jun 18, 2006 | 02:50 PM
TJTURBO's Avatar
I TRYED ALREADY BUT I THINK THEY ONLY MAKE IT FOR THE 2.2L BUT NOT SURE IF I WOULD FIT THE 2.0L
Old Jun 18, 2006 | 03:02 PM
MugenRioS2k1's Avatar
What is the advantage to a piece like this??
just increases strength in some way?
Old Jun 18, 2006 | 03:08 PM
AusS2000's Avatar
The idea is it stops the cylinder walls moving around. But many people are opposed to them and say they cause cylinder warp from when you fit them.
Old Jun 18, 2006 | 03:45 PM
kane.s2k's Avatar
They have to be welded in and that causes the warpage. You don't hear too many people complain about the S2000 sleeves walking.
Old Jun 18, 2006 | 03:55 PM
AusS2000's Avatar
I thought they were just pressed into place.
Old Jun 18, 2006 | 04:15 PM
keeps them from flexing out wards during high cylinder pressures??
Old Jun 18, 2006 | 04:55 PM
when you say "sleeves." do you mean the stock sleeves?
Old Jun 19, 2006 | 01:37 PM
VeilsideAP1's Avatar
yes, he meant the stock sleeves. These aren't the best idea. Especially one from ebay. You couldn't pay me to put that in my motor... These can also cause hot spots on your cylinder walls because of the pressure. Fitament on a block guard is the #1 issue... then cooling paths being properly designed. Don't buy it, unless you don't care...
Old Jun 19, 2006 | 01:47 PM
kane.s2k's Avatar
Many of them need to be welded. I'm not sure about that particular one but for our sleeves, I would assume so.
