Blown Ap1 Engine...what next?
Old Mar 29, 2008 | 10:52 AM
o'malley_808's Avatar
Default Blown Ap1 Engine...what next?
Well the unfortunate happend and I blew my AP1 engine due to the wastegate vacuum line melting resulting in overboosting to who knows how much psi.
I would ideally like to find another AP1 motor for a few reasons:
- 9000 redline I do favor...
- It would be a plug and play situation with my tune...
- wouldnt have to find another ECU...
AP2 Pros and cons:
- More torque resulting in getting to boost quicker/less lag
- lower stock redline? (not sure if you can safely resume 9000 redline)
- Is the .2L enough to need bigger injectors again? I have 600cc
- Would my AP1 transmission gearing work well with this motor?
Anyone have any input to this decision? I found an AP2 Motor for cheap but I dont know if its worth the hastle?
Old Mar 29, 2008 | 12:05 PM
secrets2k's Avatar
what you doin with your blown motor?
Old Mar 29, 2008 | 12:35 PM
Kyushin's Avatar
Banned
You should just send it to laskey for a rebuild and sleeve job, since you already have the core now.
Old Mar 29, 2008 | 01:08 PM
What are "Laskey"s contacts? I would get it rebuilt but up here they charge an arm and a leg. My b-series motor I supplied the sleeved block, pistons, rods, head and all he did was put new bearings, gaskets, and do a valve job with new springs and the bill racked up to around $4200.
Old Mar 29, 2008 | 02:28 PM
Danks2k's Avatar
If you are going to get a new shortblock from honda the F20 is cheaper than the F22 as well. That is what made the decision for me.
Old Mar 29, 2008 | 03:31 PM
For me its the other way around haha...I found a f22 for $1000 and cheapest I can find a f20 is $2500+shipping
Old Mar 29, 2008 | 06:09 PM
PatS4P's Avatar
Banned
I've got an AP1 motor I just pulled out with 62K that's going up for sale. Built the turbo motor first then pulled the stock.
Old Mar 29, 2008 | 09:29 PM
Anyone have any input as to which motor is actually better for turbo app? I'm kind of caught up between the two as to which one to run. Will I have to get the AP2 ECU? I currently have a AP1 ECU + Greddy Emanage. Also is the ECU wiring any different on AP2?
Old Mar 30, 2008 | 05:37 AM
PatS4P's Avatar
Banned
I believe there was a post some time ago referencing AP2 using AP1 ECU. Try search function.
Old Mar 30, 2008 | 08:46 AM
Checked it out, didnt say a whole lot other than the rpm limit which is obvious. I'm just wondering about ignition timing more than anything. Fuel Curve I can play with but if my ignition curve is all outta wack it would be a mess correcting it all in E-manage
