Blueridge catchcan
Old Jul 15, 2010 | 09:53 AM
Spoolin's Avatar
Originally Posted by JuicedS2K,Jul 15 2010, 09:47 AM
Will the crankcase still vent even if there is no vacuum pulling the air out? Saying if i just capped the manifold and ran a line from the crankcase to just a can to collect the oil?
Start your car and let it idle and then pull the both vacuum ports, the front one and the rear/middle one with the pcv; just pull the pcv out of the valve cover. Now feel the air pumping out of the ports and ask yourself that question again. It pumps out a ton of air so you dont need the pcv system anymore, just vent them both to atmosphere.
Old Jul 15, 2010 | 06:48 PM
MADjdm's Avatar
I have it - it's a nice piece and works well
Old Jul 15, 2010 | 07:08 PM
ChefJ's Avatar
-8 or -10 lines ftl. While they may look cool, if you are trying to go fast weight counds. It is nice that they have the overflow setup. I am curious why they are making it s2k specific though.
Old Jul 15, 2010 | 07:09 PM
GpWaP1 s2k's Avatar
I have one for sale. I installed it but it was never used.
Old Jul 16, 2010 | 12:36 AM
realblag's Avatar
So do you have to remove it to empty the "catch" fluid?
Old Jul 16, 2010 | 05:54 AM
siadam's Avatar
[QUOTE=ChefJ,Jul 15 2010, 07:08 PM]-8 or -10 lines ftl.
Old Jul 16, 2010 | 10:31 AM
Ek_Jak's Avatar
im rockin it too :0)
Old Jul 16, 2010 | 10:32 AM
siadam's Avatar
With that PCV in place you are effectively eliminating that 2nd line when boost is on. Which is the sole purpose of doing all that to begin with.
Old Jul 16, 2010 | 10:51 AM
JuicedS2K's Avatar
So the 2 lines coming from valve cover, its safe to just dump to atmousphere and cap the manifold?
Old Jul 16, 2010 | 11:01 AM
siadam's Avatar
Indirectly dump to atmosphere through your catch can, but yes.
Cap mani, eleminate pcv and do work!
