Bogging/sputter below 3K
Old May 12, 2009 | 01:56 PM
legendman's Avatar
Checked it today with no luck......IAC valve coming hopefully by the end of the week.
-Nate
Old May 14, 2009 | 06:41 PM
legendman's Avatar
Update:
I replaced the IAC valve but it didn't really help too much
I do feel like I smell quite a bit of fumes from under the hood but it could also just be my imagination
Not exactly sure where to go from here, so any help would be great!
Nate
Old May 14, 2009 | 06:49 PM
Slows2k's Avatar
Have you taken the e-manage out of the equation?
Old May 14, 2009 | 08:12 PM
legendman's Avatar
problem solved:
I almost don't want to admit it....
1.....I'll say it again.....1 of my spark plugs had somehow come completely loose(all others were torqued to spec.
I'm ashamed
Old May 14, 2009 | 08:15 PM
Slows2k's Avatar
Did it melt the coil? I thought you already checked the plugs.
Old May 14, 2009 | 08:56 PM
legendman's Avatar
Coil seems fine.
I could have sworn I checked the plugs, it's usually the first thing I check but I must have simply overlooked it
The tip of the coil does look a little brown but it seems to be working fine
Old May 15, 2009 | 08:12 AM
legendman's Avatar
Well, back to square 1 again.
This morning the car started doing it all over again. I checked the plugs, they were still secure. I went ahead and replaced them but it didn't help at all.
My coil packs are a little brown near the bottom (where it touches the spark plug), could that be a problem or is that color of normal wear/tear?
Old May 17, 2009 | 04:20 PM
legendman's Avatar
Weekend update:
Replaced my throttle body gasket as well as the rubber ring around the map sensor.
It's running so pig rich (10.0ish) it's ridiculous. My plugs were completely black only after two days so I replaced them again along with my primary O2 sensor.
I guess the only thing now is to get a new map sensor
Old May 18, 2009 | 03:06 PM
legendman's Avatar
Replaced PC Valve today...MAP should be in by Thursday
Old May 24, 2009 | 10:32 AM
legendman's Avatar
Update 5/24
Replaced MAP and O2 sensor and no improvement.
Will be pulling codes today
