Boost
Old Jul 6, 2009 | 06:45 AM
Headchef's Avatar
Active Streak: 30 Days
Default Boost
I'm looking for experienced opinions. I'm currently running 12lbs. on stock internals-well tuned. Can I go to 14lbs. with stock internals? (supercharged)
Old Jul 6, 2009 | 07:39 AM
SFV_S2k's Avatar
yesssiirr !
Old Jul 6, 2009 | 09:34 AM
DeadZero's Avatar
Boooooooooooost away!
Old Jul 6, 2009 | 10:55 AM
chad86's Avatar
I would maybe add a methanol injection kit just for safety, but yah 14 would be ok.. I am runnin 12 psi with my greddy turbo kit and would run 14, but the turbo is maxed out at 12 psi... GOOD luck!!!
Nevermind, found it in your mods list.... I would say ur good to go with 14 psi...
Old Jul 6, 2009 | 11:46 AM
kawi10r998cc's Avatar
I'm currently on 14 psi with turbo and methanol injection. Pushing 470hp and 344tq! Stock internals and HG and all...you'll be fine!
Old Jul 6, 2009 | 03:18 PM
Headchef's Avatar
Thanks for the help, how many miles have you been at 14lbs.?
Old Jul 6, 2009 | 06:44 PM
sbrodacz's Avatar
Banned
I'm on 26 lbs, turboed...
Old Jul 6, 2009 | 07:00 PM
AusS2000's Avatar
sbrodacz - I read your sig this time. Doesn't say anything about a built bottom end so I'm assuming you are stock like the OP. But I highly doubt you are running 26lbs on the stock head gasket. Might like to include that info with your post.
Headchef, the bottom end can handle 14psi no problem but it is pretty close to the limit of tuning. I believe some are running pressure this high with good tuning.
But for a good safety margin a 3mm headgasket is a safe bet.
Old Jul 6, 2009 | 07:24 PM
sbrodacz's Avatar
Banned
Oh yeahh... I'm running a 3mm head gasket. Thanks ^
Old Jul 7, 2009 | 11:54 AM
Headchef's Avatar
AusS2000- thanks for the heads up!
