Boost creep
Originally Posted by Revenge,Aug 18 2009, 07:59 AM
So running a meth kit would help with creep?
I was explaining that boost creep was causing me to exceed the threshold that I felt comfortable with pump gas. So instead of running a 50/50 mix of pump/race I am choosing to use meth so I don't have to worry about the creeping issues.
Originally Posted by siadam,Aug 18 2009, 07:09 AM
I've got a full 3" and mine still creeps something awful.
7lbs to 11lbs by redline.
I was forced to run a 50/50 mix of pump/race gas, as 11 lbs was putting me @ 420whp on pump gas..which I wasn't to fond of.
So I put a smaller 4/5 lb spring in, and it worked fine..but then I wasn't able to make 15lbs as easy...without going through the points where the switchover occurs.
So I am deciding to leave my 7psi spring in and go meth this winter, problem solved, lol.
haha my boost creep actually goes the other way! I hit max boost of around 18 psi and by the end of third It creeps down to 13 psi, which is the actual mechanical spring pressure. Guess I need a bigger spring.
Like previously stated a good ecu controlled electornic solenoid is a good way to somewhat fix this. You can't keep it from creeping up to the higher boost in high rpms, but you can get it to hit that boost earlier so you will have a much better powerband rather than having boost slowly creep to redline.
See the head gasket threads.
i dont know why youd ever go as low as 7 psi. No need.
12-15 is fine. i doubt youd have much creep if you just ran the car on wastegate at 12. trying to control it down to 7 will never work.
Originally Posted by OGPackin,Mar 19 2007, 03:51 PM
A boost controller most definitely can lower the boost. Not sure where your getting that from...
I have had this issue in my FD RX-7...exact same problem. On the street I wanted to run a low boost setup. My wastegate was undersized so I got a manual boost controller thinking it would stabilize my boost. Negative. I popped my motor in the winter and upgraded my boost controller with the rebuilt motor.
Spec, you can sell that wastegate for 75% of what a larger one will cost you.
Originally Posted by Spec_Ops2087,Aug 17 2009, 02:46 PM
Air is lazy and will go whichever way is easier to exit.
For an external dump:
A larger exhaust will increase the chance of causing creep -- your making the exhaust restriction less therefore the air has less resistence exiting the turbine side instead of the wastegate.
For internal dump:
It can really go either way -- it really comes down to wastegate design in the turbo and also in the downpipe
For internal dump:
Keep boostin'!...well, not 'til you get this resolved...hehe
