Boost creep
Old Feb 25, 2010 | 07:09 AM
  #61
JoeyBalls's Avatar
this thread is Super old, i think Spec Ops fixed the problem
Old Feb 25, 2010 | 07:28 AM
  #62
CourageOO7's Avatar
Awe crap...I didn't see the date after Revenge bumped it. Sorry.
Old Feb 25, 2010 | 07:37 AM
  #63
Spec_Ops2087's Avatar
Well to answer the question, I got a 44mm wastegate fitted so boost holds fine now. One of these days I need to get my AEM tuned to control boost...so much more accurate then my EBC.
Old Feb 25, 2010 | 08:02 AM
  #64
Revenge's Avatar
Thumbs down
yeah, I just brought it back because I knew he fitted a wg44 onto his inline manifold, just wounder if it was actually ported or not. Does it benefit the car to add a bigger wg to the manifold with out porting? Does it help at all cause I would think it would be the same size hole the air has to pass through. Any advice would be helpful. I have seen adapters for a 38 to 44. Could that work.
Old Feb 25, 2010 | 02:09 PM
  #65
Hole was never ported, just increased the wastegate size and it did the trick.
Old Feb 25, 2010 | 02:53 PM
  #66
justnnavy's Avatar
if no one suggested it... try taking the dumptube off and see if it still spikes... if your able to that is of course
Old Feb 25, 2010 | 03:51 PM
  #67
Revenge's Avatar
I have noticed you can get a 38 to 44 adapter. Then I guess I would need a new dump tube if I went the direction of getting a bigger WG.
Old Feb 25, 2010 | 03:55 PM
  #68
s2kswe's Avatar
Is this on a ILP cast log manifold?
Old Feb 25, 2010 | 04:29 PM
  #69
Revenge's Avatar
yes he has a cast mani
Old Feb 25, 2010 | 05:00 PM
  #70
Correct, however I had a custom flange / pipe made since the 44 doesn't fit directly where the 38mm was (it's a bit bigger). And yes, you will need to fab up a new larger dump tube.
