Boost cut off
Old Apr 21, 2014 | 09:08 AM
Tecaterob's Avatar
Default Boost cut off
I have an 06 and seems like I'm getting boost cut off sometimes. Someone told me to use the AP1 throttle body. My question, whats everyone using?
Do you modifry the AP1 body and use the AP2 intake manifold or change to the AP1 manifold also?
(I know if its the throttle body cuz I tap on it and starts to work fine)..
Thanks in advance!!
Old Apr 21, 2014 | 09:45 AM
baZurk's Avatar
Your throttle body is fine. Are you turbo or supercharged?
Old Apr 21, 2014 | 10:03 AM
Tecaterob's Avatar
Turbo
Old Apr 21, 2014 | 10:08 AM
baZurk's Avatar
Check your vacuum lines and your wastegate line. You said it is only happening some of the time?
Old Apr 21, 2014 | 10:55 AM
passmans2kny's Avatar
works fine when u tap it? what?
Old Apr 21, 2014 | 12:31 PM
Tecaterob's Avatar
I unplug the map sensor and tap the body with a small hammer.
Old Apr 21, 2014 | 12:38 PM
baZurk's Avatar
What MAP sensor are you using?
Old Apr 21, 2014 | 02:54 PM
Tecaterob's Avatar
Stock
Old Apr 21, 2014 | 03:04 PM
baZurk's Avatar
What is your target psi?
Old Apr 21, 2014 | 03:20 PM
Tecaterob's Avatar
I'm at 21psi. The car has been running great for about 4 months now.
