Boost Issue Vortech Supercharged
Old Jul 20, 2014 | 03:54 PM
KillerCom's Avatar
Default Boost Issue Vortech Supercharged
So I just got the car tuned Friday and it was running strong all Friday and Saturday. Now I'm not making any boost but then once 7500/8k rpm hits its like a switch turns on and hello boost! Not sure what the issue could be here, Vortech V2 kit, after cooler, samco hoses, greedy bov, ID1000's, walbro 255, science of speed map sensor. Running on e85 making mid 400's. Let me know if you guys can think of anything.
Thanks
Old Jul 20, 2014 | 09:59 PM
bluemetals2k's Avatar
boost leak? I'd check the couplers first, is knock control setup?
Old Jul 21, 2014 | 10:34 AM
KillerCom's Avatar
Im pretty sure he set it up, would the knock control not let it make boost? and I checked all the couplers for leaks, I see nothing. These are brand new Samco hoses, but even if it was a leak, why would it make full boost at 7500rpm+?
Old Jul 21, 2014 | 02:20 PM
KillerCom's Avatar
bump
Old Jul 21, 2014 | 03:23 PM
KillerCom's Avatar
I'm hearing some chatter coming from the motor, any ideas?
Old Jul 21, 2014 | 04:14 PM
Sideways's Avatar
I had new hoses and when I checked with a boost leak detector I found 5 leaks. Check for boost leaks.
Old Jul 21, 2014 | 08:52 PM
Fastrak5150's Avatar
Just was wondering what psi your running? as it seams every supercharged S2000 tuned by Evans makes significantly more whp than most others tuned by reputable tuners. Is this due to the dynapack dyno Evans uses that produces such high numbers?
Old Jul 23, 2014 | 08:04 AM
Mike in Detroit's Avatar
Where is Evans located?
Old Jul 23, 2014 | 08:23 AM
lude92_si's Avatar
PA.way east...lol Long drive for me but that's who tunes my car also. I made 405/240 on my comptech setup @15psi I'm also in Michigan
Old Mar 8, 2015 | 11:29 AM
KillerCom's Avatar
Close Thread
