to boost or not to boost
It's a slippery slope and you will get bored of it. It's also very expensive. Boost is addictive, you will want more. Period. Things will then start to break and it'll cost fortunes to fix.
You'll become familiar with words like intake temps, cooling, duty cycle, Bov, vents.
When you come to sell you will lose heaps.
You will change the character of the car.
There's only so fast you can go on public roads before you become a nuisance.
Beating Porsches and Corvettes will be fun though.
Your cash your choice
Originally Posted by AusS2000,Aug 15 2010, 04:56 PM
I wouldn't pull a motor down just to inspect it. Do a compression test, leak down test and inspect the fluids. If it passes all tests boost away.
another question about the rear end, my rear dif is beginning to go out, should i replace it with oem or something else?
suggestions?
also sorry if my typingis messed up. cracked laptop screen and some keys dont work well.
suggestions?
That seems to be death to the diff.......I would go the OEM route if its a DD, but obviously if this thing is seeing the track i would go with a kaaz 1.5-2 way diff. $1200-$1600
