Boost problem
Old Apr 6, 2009 | 05:36 PM
jtazz1966's Avatar
Default Boost problem
I have recently installed a Vortech on my 04 S2000. I added a boost gauge this weekend and realized I cannot go over 0 ppsi, or atmosphere. This problem exists at all RPM's. Per tech advice I was given today, I inserted the set screw on the BOV three turns. I did notice that the set screw was very easy to turn in, and I was able to do it by hand. This did not correct the problem. I am thinking that the diafram in the BOV may be leaking by, causing the valve to be forced open when the supercharger reached atmospheric pressure. I am running at idle with 20-21" of vacuum. Does anyone have any thoughts? Thanks.
Old Apr 6, 2009 | 05:52 PM
whones
Guest
Posts: n/a
are you sure the gauge works? how does your car run? I would say pressure test but not sure how to set it up on these cars
Old Apr 6, 2009 | 05:56 PM
jtazz1966's Avatar
I tested the gauge before I installed it. It works fine.
Old Apr 6, 2009 | 06:40 PM
GrandMasterKhan's Avatar
i dont get it. Does the gauge not read the boost or is your car not boosting?
Old Apr 6, 2009 | 06:43 PM
Slows2k's Avatar
Does the car feel substantially faster above 6000 rpm? If it does, the problem is the gauge. If not the problem is the car.
Old Apr 6, 2009 | 06:52 PM
jtazz1966's Avatar
I don't think the car is boosting. Though I did feel a little more power, but thats because the car is seeing 0psi vice vacuum. The car doesn't feel like it is going to 7psi though.
Old Apr 6, 2009 | 07:39 PM
Slows2k's Avatar
A N/A car will see 0 psi at wide open throttle. Unless the BOV was stuck open it's not causing a 7psi pressure drop.
Did you check to see if the belt is tight or even has one still on the pulleys?
Old Apr 7, 2009 | 07:13 PM
jtazz1966's Avatar
The belt is fine. How could I determine if the valve is stuck open?
Old Apr 7, 2009 | 07:19 PM
Slows2k's Avatar
Unbolt it from the aftercooler and look so see if the valve is of the seat. I'd bet it's not.
2003SCs2k
Nov 17, 2013 01:38 PM
sata3000
Jun 23, 2012 07:16 AM
crav3s2k
Jan 3, 2009 10:36 AM
s2kkyo
Dec 9, 2007 10:46 PM
jahnke
Jan 29, 2005 04:37 PM
