Boost Questions
Old Mar 21, 2008 | 08:22 PM
duanet85's Avatar
Default Boost Questions
alright so a few questions about boost, i thought it would be acceptable to post in the forced induction thread. looking to boost in the next year-ish? i have read on different threads, but also found different answers for each so i'd like to confirm an exact answer from the guys who have done it.
1.) ctsc/ac - can use stock injectors correct? how far away from the "line" are you from having to change injectors?
2.) ctsc/ac - is a bigger diameter exhaust needed?
3.) spark plugs - stock plugs or junk 'em and go for a different set? I dont know how plugs work exactly, like if they are "one step colder" i dont know what that means so dont laugh.
4.) Hondata K Pro - can you use this to control a ctsc/ac set-up?
5.) Fuel Pump - How far can the stock be stretched?
6.) plan on doing a project like the Honda F24 build in JDM Tuning (found here...https://www.s2ki.com/forums/index.ph...ic=538548&st=0), but would also like to throw a low boost on it. wondering if Hondata can control both?
7.) any info you think would be knowledgeable would also be appreciated.
Old Mar 21, 2008 | 10:36 PM
Spec_Ops2087's Avatar
1. Yes, if you want to run more then 7psi you'll need larger injectors
2. No
3. Stocks are fine but maybe run on stage colder plug but I'm not a spark plug expert either.
4. Expensive and complete overkill unless your looking for 400+ hp but yes I'm sure it could work.
5. No idea, but why chance it?
6. Again, I can't see why not
Old Mar 22, 2008 | 07:37 AM
duanet85's Avatar
thankyou, thats everything i wanted to know. much appreciated
Tareks2000
Jan 30, 2017 09:13 AM
rvpjr123
Forced Induction For Sale
Apr 29, 2016 04:44 AM
JoeyBalls
Dec 23, 2013 07:13 AM
wildkart
Nov 19, 2013 07:32 PM
Kyushin
Apr 7, 2009 03:58 PM
