Boost-a-Spark users
Old Oct 7, 2012 | 06:08 PM
99SH's Avatar
Default Boost-a-Spark users
I just finished installing the Kenne Bell Boost-Spark in series with the stock wiring. The BAS unit has nice hefty 12 AWG power wires. The stock harness is somewhere around 18 AWG and very weak in comparison.
Any issues installing the BAS as-is with the stock wiring? OR it is worthwhile to upgrade to 12 AWG? If upgrading to 12 AWG, we still hit a bottle neck from the harness connector to each individual coil.
Thoughts?
Old Oct 7, 2012 | 06:25 PM
hybrdthry911's Avatar
What issues are you having? We had no issues making plenty of power on stock ignition.
Old Oct 7, 2012 | 07:06 PM
indi00's Avatar
I cut the BLK/YEL wires right before the first BLK/YEL split to the first coil. Combined them into one wire and soldered to the IN RED wire. The OUT RED wire is then soldered to the individual BLK/YEL wires to the coil.
Thought about setting up a relay and run IN RED + straight to the battery 12AWG like the fuel pump relay mod.
The benefit of this MOD? Was getting misfire and break ups around 6500 to 8000rpm at BKR8EIX 0.018 gap.
With the KBAS, I run stock BKR8EIX gap with no hiccups.
Old Oct 7, 2012 | 07:12 PM
99SH's Avatar
Spark blow-out at higher boost levels & RPM. I'd like to run a 0.030" gap and see what happens.
Ultimately I'd like to run the BAS directly off the battery and tie all 4 coil outputs to the BAS output. Before I do anything, I'd like to measure the current to see if this is indeed necessary. The BAS has a 30A fuse and stock fusebox is 15A. Do you know how much current we really pull?
Old Oct 7, 2012 | 07:30 PM
indi00's Avatar
Have no idea on the AMP draw. One of these day I might put an AMP meter on it just for giggles..
Old Oct 8, 2012 | 11:32 AM
mattie170's Avatar
Sorry but I don't have a answer for you but trying to achieve the same thing. I have spark blow out at higher rpm's and trying to keep the gaps as far open as possible. I have gone for the AEM CDI and AEM Pencil Coils. Never heard of a Boost-a-spark so went the AEM route.
Old Mar 7, 2013 | 06:48 AM
soulicious's Avatar
I just got a BAS. I am having blowout even with a .018 gap on my bkr8eix plugs. Does anyone have any install pics? I'd like to check out some mounting locations. Also, does anyone have any pics of the black/yellow wire that needs to be cut?
Old Apr 18, 2013 | 07:33 PM
neeman77's Avatar
Anyone know where the wire for the coils splits off from the 1 black and yellow wire to the 4 individual wires? Is it in the bay or by the fusebox? Thanks!
Old Apr 19, 2013 | 08:43 AM
99SH's Avatar
I mounted mine where the passenger airbag would go. Perfect location and there's a harness close-by that contains the coil wire.
Based on the electrical shop manual, it's by the fuse box inside the cabin.
Old Apr 19, 2013 | 09:54 AM
soulicious's Avatar
Thanks. I already installed mine where the horn in the engine bay used to be.
I just cut the 4 wires by the firewall and combined them into one. Car seems to be a lot smoother now.
