boosted to burnt to built
My motor is sleeved so I have JE pistons
Here are some before and after pics of the intercooler and turbo. I was so ready to clean them that I didnt snap any pics of them right before.
intercooler new:
This was the front side of the intercooler so the soot wasnt bad but the end tanks kinda show how bad it was. I havent cleaned the front yet
The back side was pretty bad but this is how it looks now. It was a pain cleaning all the bars since it doesnt take much to bend the fins.
Now onto the turbo compressor housing:
when I first got it (flash on)
covered in soot
after cleaning and going through 5 of the hard polishing wheels on the dremel (flash off)
The compressor housing is actually much shinier then when I first got it
The radiator got it the worst but thankfully my fan shroud and fans took the majority of the abuse. An aluminum fan shroud will be easy to clean and fans easily replaced. I've decided that I might as well polish the compressor housing completely. I already have plenty of 400, 600, 1000, and 2000 grit sand paper so why not. The only thing is now I'm going to have to polish my intake manifold too
considering my intercooler pipes will be polished....I hate making more work for myself but at least my labor is free and my engine bay is going to look really good. After I sand them down I'll take them to a local polishing shop and let them buff it using their giant buffing wheels, tools, and experience....I think the buffing step is a little to big for me my trusty dremel.
intercooler new:
covered in soot
Yea the small of displacement isnt anything.
I was curious because I run the OEM 2.4 stroke. Technically 2.363
I run the a 99mm crank
With 5.36" rods.
It makes for a horrible rod/stroke ratio. I did plan on going another route but I got the mahle pistons for a steal and couldn't pass them up.
I'll be paying close attention. Very interested in seeing what you do. :-)
With 5.36" rods.
With 5.36" rods.
With 5.36" rods.
It has been a long time coming but since it's spring time my car is on my shops schedule to get my sleeved motor installed and get a retune. I am a running a Garrett GT35R and I know maxing that out will not be a problem on my new setup. My final power goal is 900whp but my concern is that I have a equal length tubular topmount manifold but it has a t3 flange. It seems having a t3 manifold will limit the selection of turbos to chose from that can hit my power goal, am I right in assuming that? Right now I am looking to switch to the Precision 6766 CEA since it has a t3 option and is rated to 935hp. Does this sound like a good approach or should I rethink some things?
