boosting 124k mile ap1
Old May 13, 2013 | 11:22 AM
  #101
herecomesboost's Avatar
Is the end of the input shaft machined to stock diameter/length (going to use the OEM pilot bearing/flywheel?)
Old May 13, 2013 | 12:53 PM
  #102
siadam's Avatar
Originally Posted by bobbyrandolph440
well the test is done what do you all think it's coming along nicely
the T 56 with the s2000 bell housing adapter on the left on the right stock s2000
Sent from my DROID RAZR using Tapatalk 2
Can you provide some more info on this?
As in, who did the work, what is the tranny aside from a t56? Specs/price/etc?
Would be a nice alternative for those not willing to part with the price tag of a v160.
Old May 13, 2013 | 03:13 PM
  #103
bobbyrandolph440's Avatar
Everything will work like stock they cut off the stock pilot and pressed one on the size of the stock s2000 pilot also they used the adapter plate to push this bell housing out far enough to use the exact same length of the input shaft as the stock s2000 tears all the pictures G Force has posted for me
Old May 13, 2013 | 03:15 PM
  #104
The ap2 8k redline is about the max a t56 will shift at with out problems i had my t56 face plated and cryo treated also had the stock s2000 bell cut and welded to mate rite to the t56 i will u all stock s2000 Clutch parts but gm 26spline on the disk it cost no more to have this done from comp clutch
Well this is break down on cost
Stock s2000 bell 100.00
Gforce cut weld and all fab work plus the custom pilot on t56 620.00 shipped
Liberty faceplated stock gears and cryo treatment 980.00
Comp clutch 1250.50
Break down and rebuild of t56 340.00
Stock t56 from trans am 1000.00
So all in all 4290.50 but the best thing about this trans is there easy/cheap to work on and find parts for
Old May 13, 2013 | 07:50 PM
  #105
Irishflame27's Avatar
god i want this!
Old May 13, 2013 | 08:11 PM
  #106
Phill24's Avatar
Looking good bobby
Old May 13, 2013 | 08:13 PM
  #107
siadam's Avatar
Originally Posted by siadam' timestamp='1368478400' post='22539863
[quote name='bobbyrandolph440' timestamp='1368467363' post='22539297']
Comp clutch 1250.50
[/quote]
I appreciate the info. Last I remember the t56 wouldn't spin the r's. 8k isn't even the stock redline of an ap2, of 8200, and the poor ap1 guys @ 9,000. With my built head/etc, I plan to be tearing up 9k and digging into 10k territory.
I was hoping for some better news.
Again, thanks for the info.
Old May 13, 2013 | 08:36 PM
  #108
Originally Posted by bobbyrandolph440' timestamp='1368486920' post='22540165
[quote name='siadam' timestamp='1368478400' post='22539863']
Comp clutch 1250.50
[/quote]
[/quote]
His faceplated 1-4 gears will shift at 10k no issues...
Old May 13, 2013 | 09:33 PM
  #109
Comp clutch 1250.50
[/quote]
[/quote]
Ya 10k will shift like butter =) faceplated gears i have seen to 10800 with smooth ingagement so there will be no problem with that at all
Old May 13, 2013 | 09:34 PM
  #110
Originally Posted by Phill24
Looking good bobby
Thanks alot i just want it going so bad i cant stand it haha
