boosting 15psi without headgasket?
Old Mar 5, 2008 | 04:21 PM
  #21
Silver S2k4's Avatar
104 is $8.50 at a local gas station near me.
Old Mar 5, 2008 | 07:05 PM
  #22
Spec_Ops2087's Avatar
Originally Posted by ace123,Mar 5 2008, 07:23 PM
OPEC limiting supply is responsible for a fair bit of the oil prices
but at $4 a gallon it makes me wonder... maybe $6 race gas wouldn't be too bad, as i only get 2 tanks a month!
C16 race gas (116 octane) is about ten dollars a gallon depending on the area
Old Mar 6, 2008 | 12:53 AM
  #23
wingnutLP's Avatar
LOL, if you think that's bad you should try the UK.
Our regular premium fuel which is 97 ron is
Old Mar 6, 2008 | 02:24 AM
  #24
Envied's Avatar
yeah but the cost of living period over there is more... look at your average income there and then look at average here... lol
Old Mar 6, 2008 | 02:36 AM
  #25
MrHonda's Avatar
Originally Posted by Spec_Ops2087,Mar 5 2008, 10:46 AM
Not sure what RON is but usually 105+ octane is considered race gas.
RON is Research Octane Number. It is a method of rating anti-knock properties. Another is MON, Motor Octane Number.
What we typically use in the US if Pump Octane Number, which is an average of RON and MON.
Old Mar 6, 2008 | 05:23 AM
  #26
plokivos's Avatar
the major problem with the meth injection is either the pump failing or electronics failing.
i wouldn't run meth daily. there is a higher failure rate. but it's cheap compare to running race gas everyday.
Old Mar 6, 2008 | 10:52 AM
  #27
liketobike's Avatar
I think when i go turbo, im gunna go with e85
Old Mar 7, 2008 | 05:03 AM
  #28
S2Kart's Avatar
Like most car mods, there are lots of ways to make it go booom.
There is nothing special about the pumps or electronics - don't think meth injection necessarily has a high failure rate. Buy a good one and don't go overboard with the spray rate. Some kits have self-monitoring that will pull timing and/or boost. That is safer than alot of the ECMs out there. Of course there are probably cases where someone took an aquarium pump, ran straight meth, and tried 20psi boost
If you run a moderate injection rate, maybe 2-3 gph, and you can keep your AFR safe whether the injection is on or off. Remember, its 40-50% methanol and the rest is water. Also, meth has a lower energy potential than gasoline, so it really does not enrich the AFR that much.
Don't go crazy with the amount of timing you add. Use an ECM that preserves the stock ECU function of pulling timing based on knock sensor input (like the Emanage ULT). If the meth/water fails (and you'll know via warning light) and if the ECU detects knock you're ok, plus get off the throttle.
Old Mar 7, 2008 | 03:37 PM
  #29
AusS2000's Avatar
Originally Posted by passmans2kny,Mar 6 2008, 05:33 AM
i want RON 98
98 RON is 93 MON.
BrockB
Sep 24, 2010 11:42 PM
combats2000
Jul 1, 2009 07:18 PM
codeman
Jan 11, 2009 11:17 PM
finalkillss
Aug 29, 2008 05:17 AM
zaid175
Jul 23, 2007 03:01 PM
