Borgwarner s200sxe set up help
The one hole on the compressor housing is to source vacuum for the wastegate/gates. The other I'm not sure. The oil feed and return line will work you just have the feed connected in the wrong spot. Feed through top of center housing drain out the bottom. Feed has to be on top with the drain directly vertical below. Look up clocking a turbo. It's so you can configure the housings in the right direction along with keeping the center housing vertical.
No problem! Let me know if you need anymore help/pictures. I was in your position before and a lot of people like to just be jerks and tell you to research. Well that only takes you so far, then it's nice to learn and get info from real people who know what they are doing.
The other hole is for a wheel speed sensor, which I think doesn't come pre drilled from the factory (not that sure on all Borg turbos) but better check if it is. If in fact it is a hole going thru the inside, you need to plug it
If you're running a single wastegate, the pressure port off the front of the compressor housing should go to the bottom port of your gate. Depending on what type of boost controller you're using, you may also run a line to the top port.
