BOV on Vortech supercharger
Old Feb 17, 2003 | 01:09 PM
DraggnDropTop's Avatar
Souldnt this kinda work
i was told that they had a screw or something on it to set the pressure of when its activated and releases the pressure, it seems if i set it around 8 psi it would work, but i dont think its "smart enough" to release only the pressure above 8 psi.
but if there is a solution im sure my mechanic can find it, he is well known, and my car goes in the shop in two weeks. if i find a solution ill make sure to post it
Old Feb 17, 2003 | 02:09 PM
spapdx's Avatar
Nope, thats a blow off valve. Which like we said earlier is either releasing all the boost or none...
Old Feb 17, 2003 | 02:18 PM
KAMcDonald's Avatar
or he is talking about a popoff valve... opens at a pressure determined by strength of spring. from i read on it, not all or none, only pressure excess of set level.
designed as a safety check to vent pressure if the turbo wastegate gets stuck open
blowoff valve vents pressure when you get off the gas
keith
Old Feb 17, 2003 | 02:57 PM
fperra's Avatar
KAMcDonald, what RWHP are you getting with the Comptech SC?
Old Feb 17, 2003 | 03:05 PM
KAMcDonald's Avatar
i am pulling about 267 rwhp as measured on a mustang dyno.
keith
Old Feb 17, 2003 | 03:23 PM
fperra's Avatar
Thats pretty darn good. Better than 300 on a Dyna and no intercooler. Are you running 93 octane or racing fuel?
Old Feb 17, 2003 | 03:34 PM
KAMcDonald's Avatar
sunocco 94.
pete is getting around 307 with a 4.25 pulley and 103 octane on his '02
he is working on an aftercooler setup while i try the emanage setup. i will probably try the aftercooler once he works outs the bugs, but he says he is happy with just using the VAFC for now.
i really want to drop on my 3.875 pulley and it looks like i need both to be really safe.
this is also why i am looking into ways to release extra boost so that i can get boost earlier in the RPM range without blowing up the stock internals. the tech we use showed us a setup on another car that might work for us, will take a couple weeks to find out.
keith
Old Feb 22, 2003 | 08:19 AM
fperra's Avatar
What you need is a variable size pulley - as rpm increases, pulley diameter increases. This is technically possible to do, but I'm not sure anyone has made one yet, except in some automatic transmission applications. Another possibility would be a clutch arrangement on the pulley that governs the speed of the pulley. This approach has been used in the past on some industrial machinery.
Old Feb 25, 2003 | 07:15 PM
Wildncrazy's Avatar
There are several SC kits out there that do use a different pulley and a BOV to give the boost earlier.
I know of one with a Whipple and one with a Roots. I have never seen it done on a Centrifugal, but there is no reason it wouldn't work.
Old Feb 26, 2003 | 08:32 AM
spapdx's Avatar
So they use the Blow off valve to controll boost psi??? I didn't think that was possible.....
I thought that a wastegate is used to controll boost pressure and the BOV releases all boost once throttle is let off..........
