Breaking 15psi
Old Oct 6, 2006 | 08:27 AM
Sideways's Avatar
[QUOTE=PRS2K,Oct 6 2006, 09:20 AM]Boosting 10psi on stock compression is not good.
Old Oct 6, 2006 | 08:30 AM
Spoolin's Avatar
[QUOTE=PRS2K,Oct 6 2006, 12:20 PM] Boosting 10psi on stock compression is not good. TRUST ME!!
If your asking can you boost 10psi on stock compression? The answer is YES. Is it a good Idea to do so? Absolutely NOT.
Inlinepro sales the 3mm Head Gasket for 2 reasons.
1. To take advantage of the factory forged Internals
2. Making it safe to take advantage of the factory forged Internals
With this being said they have proven time and time again that this head gasket works! John has had his car in the 10
Old Oct 6, 2006 | 09:11 AM
S2K:-)'s Avatar
What turbo is it? Depeding on he trubo sizing, at 15psi, you may have to build the block...
It's a gt32/55
Wouldn't he get the same benefits by not using the 3mm HG and just staying with the stock CR and just boosting around 10 psi?
I don't want 10psi I want 15psi.
Old Oct 6, 2006 | 10:01 AM
PRS2K's Avatar
[QUOTE=Sideways] Why should we trust you?
Old Oct 6, 2006 | 10:27 AM
dmw16's Avatar
dont mean to be a stickler, but the is 3 BAR map sensor. A bar is a measure of pressure...
Old Oct 6, 2006 | 11:05 AM
timg's Avatar
Your manifold design, exhaust, and turbine will also affect how much boost you can safely run on a stock motor.
Tim
Old Oct 6, 2006 | 11:27 AM
jbotstein1's Avatar
I would also like to know what Spoolin is asking. Maybe I can ask it more clearly. I am running 11 psi on 9:1 Comp pistons and I make about 370 whp. Now someone running 7-8psi can also make 370 whp at 11:1 compression. What is the advantage of running the lower compression ratio in this situation? I did it for the added safety, althoug my engine is a bit overkill for my setup. Spoolin, is that what you were asking?
Old Oct 6, 2006 | 01:42 PM
OGPackin's Avatar
I run around at 17psi and i have had it up to 20psi with no probems...
psss....3mm hg all the way...
Old Oct 6, 2006 | 01:58 PM
Black Nugget's Avatar
[QUOTE=Sideways,Oct 6 2006, 11:27 AM] Why should we trust you?
Old Oct 6, 2006 | 05:00 PM
j_c_a's Avatar
3mm gasket and hit 20 psi daily
