Calling All ID2000cc Users!
Old Dec 9, 2010 | 07:06 AM
InductionPerformance's Avatar
Very nice fuel setup Irishflame27
Old Dec 9, 2010 | 07:28 AM
Irishflame27's Avatar
thanks alot man, i wish i did dual 044's from the get-go tho lol
Old Dec 9, 2010 | 07:34 AM
kutsujula's Avatar
Originally Posted by bolisbuilt,Dec 9 2010, 07:32 AM
Is anyone running twin 044's? If so, what is the setup? I am looking into changing some things for next season as our current setup is maxed. Twin 044's seem to be the only way to accomodate big numbers(700+).
I have twin 044's and 8 ID1000's
Old Dec 9, 2010 | 08:48 AM
D1sclaimer's Avatar
Originally Posted by Irishflame27,Dec 9 2010, 08:41 AM
does KPRO have the same fine tuning for injectors as AEM does? Im running KPRO and dont want to have issues with fine tuning.....
Joey, ILOVEMYHONDA1984, is running the ID2000 injectors with his Kpro on his s2000 so I would assume it does. I don't think he has any complaints.
Old Dec 9, 2010 | 09:15 AM
tony1's Avatar
The K Pro has no problem controlling them properly at idle, they don't use the same mulitplier type deal as the AEM with the microsec/bit value. No system out there has a problem with them when tuned correctly, not knowing about the 75 msec/bit needing to be changed is just something that wasn't known of and was figured out, just part of tuning.
Old Dec 9, 2010 | 10:14 AM
Shftat9k's Avatar
Where are you guys getting these to idle at? What partial throttle afr also?
Old Dec 9, 2010 | 02:20 PM
dsddcd's Avatar
Actually we have been having issues with the idle and startup. I have not messed with this yet but Tony's comments by not using the changing the value for the Injector size makes sense.
Old Dec 9, 2010 | 02:39 PM
MaseEngineering's Avatar
Banned
the idle issue joey is having is because the tune has the close loop turned on (which he wanted when i tuned it). the o2 is correcting it to stoich. if you turned off closed loop you can get it to idle smooth.
Old Dec 9, 2010 | 06:52 PM
dsddcd's Avatar
We turned it off b/c of that issue
It is strange, I can't seem to command anything under 1.0 ms so the idle is super rich.
Old Dec 9, 2010 | 07:23 PM
D1sclaimer's Avatar
[QUOTE=dsddcd,Dec 9 2010, 05:20 PM] Actually we have been having issues with the idle and startup.
