can AEM adjust for change in temperatures?
as the title says, can it adjust? Like lets say you tuned it for the summer temps (90 deg), but then during winter the temps drop to 40's or 50's (or vice versa)... will that tune run fine, or should it be modified a bit? I would think you can advance more timing with the colder temps, but need to increase teh fuel? Would AEM adjust for these changes? Or am I over thinking this ? Was always curious but just wanted to know.
I thought they only thing that would adjust was the a/f when you plug in a uego sensors and it would adjust the fuel mixture to make it what you want based on uego inputs.
Also does it automatically adjust itself or does the tuner need to program it to adjust itself?
The AEM has the capacity to do all of the above, but each parameter has to be set manually. So, for example, if you want it to pull some timing in hotter temps you need to bring up the map and set the range/amount of adjustment.
