Adding rows to maps?
Old Oct 19, 2010 | 07:53 AM
TerminatioN's Avatar
Default Adding rows to maps?
Is it possible to add rows to fuel/timing/etc. maps on the AEM EMS? What about the Kpro?
I currently have the AEM EMS and I haven't found a way to do it... so I'm guessing its not possible... Am I right?
Is it possible to do with Kpro?
To clarify, I'm talking about how it seems like it only has X ammount of rows, and while you can change the values of those rows it doesn't seem like you can add additional rows...
Old Oct 19, 2010 | 09:53 AM
Dan1987's Avatar
You can certainly add rows with FlashPro so I imagine you will also be able to with Kpro also.
Old Oct 20, 2010 | 10:28 AM
maluch's Avatar
you cannot add rows in AEM EMS.
if you are looking for additional sensitivity in the map try using non-linear breakpoints. so in the heavily used cells use 250 rpms increments as opposed to 500. similarity with pressure...
AlpineFD
Aug 16, 2018 12:37 PM
SHIFTAT9
Oct 13, 2011 11:31 AM
slizzle
Mar 6, 2009 11:08 PM
03S2KAY
Nov 16, 2004 02:42 PM
