can AEM serial gauge read air fuel
what sensor do i need to buy for my aem serial gauge for my aem ems so it can be used as a wideband to read air fuel mixture?
do i just buy the sensor? how do i wire it up to the aem ems?
http://cgi.ebay.com/ebaymotors/AEM-UEGO-OX...sQ5fAccessories
or do i buy this?
this is a wideband kit with out the gauge but this is only $20 less than a uego kit with a gauge.
http://cgi.ebay.com/ebaymotors/AEM-Inline-...=item3f04208ca3
or do i buy this?
or do i buy this?
or do i buy this?
you need the uego wideband kit , or any wideband sensor & gauge (plx, ngk etc), it can be wired into your EMS. Im not sure of the specifics, mine has it built in.
i have an AEM ems series 2 ecu and i have the aem serial gauge which plugs into the ems.
I just want to know what exactely i need to buy so my serial gauge can be used as a wideband
did your aem ems come with the wideband sensor? if not, then you need the sensor, then wire it in, then calibrate it in the software, then setup the serial gauge to view it, then it will work.
short answer, yes it can work.
Banned
which ems do you have?
if the part number does not end in a U then you will need one of the many uego kits they sell.
they sell 2 different gauge types and one non gauge type, they all run ~$180
If you do not already have a serial gauge and want to just measure afr, then just get the aem wideband gauge
Yes, you can run any wide band with any aem ems.
All 3rd party wide bands come with a controller. Thos controller turns small voltage from the o2 sensor itself into a signal the ems can understand.
The 1050u has a built in controller for the aem specific wideband, but any 3rd party wideband (with controller) will work.
Third party gauges get their info to display from the controller (circuit), not the ems.
I run both the serial gauge and the inovate wideband brand gauge
my aem is a 30-6052 which is a series 2 for my 2002 s2000
i also have the aem serial gauge.
can some one post a link on exactely what i need to buy inorder for me to rear air/fuel on my serial gauge.
