Can Hondabond hurt your engine?
Old May 5, 2010 | 08:20 AM
Competitor9's Avatar
Default Can Hondabond hurt your engine?
Pretty much exactly what the title says.
I dropped my oil pan to tap it for the return line for my inlinePRO kit and when I cleaned it up and re-installed it with hondabond, once all the bolts were tightened down the hondabond squeezed out the sides. I used the hondabond pretty liberally along the edge of the oil pan.
I am just curious as to if the hardened pieces of hondabond will make their way through my engine I imagine that they would since they are not heavy and probably float somewhat in the oil, and if they do would it cause engine trouble.
Old May 5, 2010 | 08:26 AM
s2k dre's Avatar
It wont hurt anything.
Old May 5, 2010 | 08:51 AM
Deception's Avatar
Oil filter will stop anything that gets sucked up
Old May 5, 2010 | 09:12 AM
TRBOKEV's Avatar
No problemo, Honda did the same thing when they assembled the engine (hondabond squeezed out all over the place.)
Old May 5, 2010 | 09:19 AM
D1sclaimer's Avatar
What if, in the unlikely event, that the bypass valve lets it through?
Old May 5, 2010 | 09:55 AM
siadam's Avatar
I wouldn't think...it would burn up in the motor...and I would doubt it would be to fine to squeeze between a bearing.
I wouldn't worry w/it.
Old May 5, 2010 | 10:29 AM
spectacle's Avatar
You'll be fine.
Old May 5, 2010 | 10:33 AM
neeman77's Avatar
Most of it wont get by the screen in the oil pickup the rest will go to the filter. Its alright.
Old May 5, 2010 | 11:03 AM
s2000Junky's Avatar
It will just get sucked up to your oil pick up screen and block the oil, starving your engine of lubrication. But no worries
Old May 5, 2010 | 11:07 AM
neeman77's Avatar
hahaha I'm sure it wont even fall off the side of the pan where it squished out of, its fine.
