Can the OEM header heatshield be re-used?
Old Aug 4, 2009 | 08:06 AM
jari8378's Avatar
Default Can the OEM header heatshield be re-used?
Did a search, and i couldnt find anyone who tried this. My assumption is that I might be able to re-used the top portion of the OEM header heat shield on the greddy turbo manifold. Would the OEM heat shield withstand the heat of the turbo manifold?
chime in.
Old Aug 4, 2009 | 08:08 AM
JoeyBalls's Avatar
I never used a heat shield, it was fine
Old Aug 4, 2009 | 08:34 AM
TelosHedge's Avatar
thats just flat out not going to work. there is nowhere for you to bolt the factory shield up to the manifold as there is no bracketing on the greddy mani.
you can, however, reuse the black aluminum heat shield that covers the battery and fuse box if you cut part of it.
ghosta9
Mar 14, 2015 09:51 AM
cujet
Jan 11, 2015 05:30 AM
tx2K
Oct 27, 2013 06:12 AM
min0527
Apr 6, 2013 03:01 PM
chrisaltima
Mar 21, 2012 10:53 PM
