Car falls flat on its face!
Ok, I'm hoping you guys can give me an idea of what is going on with my car.
The car runs absolutely amazing when I get in the car and start off. Once the car starts to heat up the temp gets to about 205 degrees... The Temp outside has been around 105 so I think this is maybe an issue also. Once the car gets to 205 degrees it completely dies it wont idle, cruise, absolutely nothing until it cools back down.
I was told to move the map sensor off the manifold and mount it on the firewall so maybe it wont get so hot.
Any suggestions would be greatly appreciated.
I don't know what would cause this, but I'd suggest venting your hood to reduce temps and hopefully keep it from happening. Here's the DIY thread:
https://www.s2ki.com/forums/index.ph...&f=22&t=324009
205 is pretty much perfect temps for fuel combustion and atomization. research what are actually "good temps" for power, etc.
seems like a coolant temp to fuel trimming issue in the map.
eolife22
21
Jan 7, 2009 04:34 PM
