car is randomly shutting off?
Old Mar 1, 2010 | 01:54 PM
ChefJ's Avatar
if you have an oil pressure gauge you can watch the pressure drop at idle as you depress the clutch = a good sign its crankwalk. Hopefully just a dirty sensor or corroded wire
Old Apr 12, 2010 | 06:26 AM
Chow-bot's Avatar
Bumping my old thread since i just started driving the car again
i do have an oil pressure gauge installed and the pressure drops when the clutch is depressed.
i am at work today but will be checking it when i get home,
fingers crossed
Old Apr 12, 2010 | 06:43 AM
JoeyBalls's Avatar
what kind of Clutch do you have?
Old Apr 12, 2010 | 06:53 AM
Chow-bot's Avatar
competition 6 puck- not sure of stage
competition flywheel
havent seen much in terms of crankwalk with competition, just ACT
Old Apr 12, 2010 | 06:54 AM
JoeyBalls's Avatar
^ yea thats what i thinkin
Old Apr 12, 2010 | 06:59 AM
devs2k's Avatar
My engine crankwalked but I don't think that may be your problem, sounds electrical. In any event, what clutch/pressure plate did the previous owner run?
Old Apr 12, 2010 | 07:03 AM
Chow-bot's Avatar
the same one, but never experienced any problems with it.
with the clutch depressed my oil pressure has hit about 20psi a few times,
i am hoping it is not- the car does seem to run well
Old Apr 12, 2010 | 07:06 AM
devs2k's Avatar
With the car on and someone depressing the clutch pedal, I was able to see my crank pulley move in and out. At this point, however, I had thrust washers laying in the oil pan.
Old Apr 12, 2010 | 07:09 AM
Chow-bot's Avatar
yea, i have read your posts in regards to your crank walk,
i will check to see if anything happens tonight and go from there,
Old Jun 6, 2010 | 02:43 PM
hondabim's Avatar
I have the same problem, if you push in the clutch and the car drops rpm or stalls , then you have a thrust washer problem. Look at your crank pully and get some one to push In the clutch and see if you have any push and pull play!!!
I have a act pp and the engine is 3 weeks new from laskye raceing!!! I am call mike on Monday!!!!
