Car is running lean under boost
Old May 17, 2013 | 01:35 PM
cmn's Avatar
cmn
Default Car is running lean under boost
So, I have been having some problems lately with the car not running like it should. I have checked just about everything I can think of. The car is running lean under boost. It has nothing to do with rpm's. If I'm light on the throttle, the AFR are fine all the way up the rev range. I have checked for leaks in the connections in the intercooler piping, adjusted the valves, changed the spark plugs, coil packs, fuel pressure regulator and fuel pump. Still acting the same.
Any ideas what it could be?? Would really appreciate any help!
Old May 17, 2013 | 04:06 PM
urBan_dK's Avatar
What engine management are you using? What MAP sensor?
Old May 17, 2013 | 09:24 PM
s2kt3's Avatar
The tune ?
Old May 17, 2013 | 09:51 PM
03supers2k's Avatar
retune
Old May 17, 2013 | 11:49 PM
cmn's Avatar
cmn
I'm using AEM (series 1). The MAP-sensor is Omnipower (4 bar). How can the tune just change all by itself?... Or could it be since the engine was brand new and has "worn in", so I now need to retune? The engine has about 2000 miles on it now.
Old May 18, 2013 | 02:45 PM
sohc_mshue's Avatar
Sounds like loss of fuel pressure under high flow demand
Old May 18, 2013 | 06:07 PM
Ahnold's Avatar
This.
What fuel pump?
I had a Walblow when mine was tuned to about 11.5 A/F. It gave out after about a year. Put in a DW 340 after the failure, at the same base fuel pressure, and found i was running really rich afterwards.
Something to check anyway.
Old May 19, 2013 | 01:36 AM
cmn's Avatar
cmn
I had a Walbro 255, but just put in a Aeromotive Stealth 340. Same thing happens.
Old May 19, 2013 | 03:33 AM
Thunder-rush's Avatar
Check the map sensor..for leaks and the plug connection. I had problems with one of the pins in the plug and had the same problem. Inspect it clean the map with carb cleaner..etc.
Mshaner79
Dec 23, 2018 06:45 PM
crxrex
Aug 30, 2018 07:45 AM
dubojr1
Nov 9, 2017 07:55 AM
chls2k
Feb 15, 2008 12:04 PM
SM00TH976
Jan 19, 2005 12:32 PM
