Car wont start....only turns over...
Old Dec 3, 2010 | 01:19 AM
vietdragontekx's Avatar
battery getting enough voltage? had the same problem couple days and it was battery not giving enough voltage. jumper it and it start right away, also check Ign coil fuse, mine blown out last week and it keep cranking all day. after that take spark plug out and connect to coil, have someone crank it for you while holding the gas pedal all the way to floor so the anti gas flood kick in. see if you can see any spark coming out of the plug when ur friend or whoever cranking it.
Old Dec 3, 2010 | 06:44 AM
Suzuka_Joe's Avatar
You should be running one step colder plugs. Not stock plugs
Old Dec 3, 2010 | 07:22 AM
siadam's Avatar
I'd agree, but that wouldn't be his issue with starting.
Old Dec 3, 2010 | 11:16 AM
MasterForce's Avatar
So i found out what it was!!!
First it was the plugs i had...they were one step colder. Why? because the old stock ones started right up. and it was around 50F outside. I see not reason to run colder plugs while winter. ill wait for summer to get colder ones. Next culprit was the type of gas i was running through it. I always gassed up at Exxon with their 93 octane. I went out of town and i only put 91 because they did not have 93. Car always started up even when it was 24F outside with NO issues. I started putting 91 gas from on base now and i have yet to experience any cold starts. When i fouled the one step colder plugs i went and put new stock plugs which i am running right now.
I contacted Chris @ SOS and all he could recommend is to let the car idle for 2 seconds before pressing the gas.
Now for a questions... Should i get one step colder plugs even though its gonna get colder outside now?
Old Dec 3, 2010 | 12:25 PM
daicacharco's Avatar
Get a Etune from evans tuning.
Old Dec 3, 2010 | 12:37 PM
soulicious's Avatar
I use plugs (BKR7E) with a heat range of 7 year round with no startup issues on 91 oct for my SOS setup w/3.8" pulley. I have a EMS though.
Old Dec 3, 2010 | 01:01 PM
siadam's Avatar
If the one step colder plugs are keeping your vehicle from starting, you have other issues.
Spark @ the plugs should be MORE than sufficient unless your not getting enough voltage.
Look into your ignition system/battery.
Old Dec 3, 2010 | 04:15 PM
Battery is good because its a 3 week old DieHard Gold. im thinking it was the gas because im not getting it anymore cause im using 91.
Walnut
Apr 14, 2021 05:03 PM
ROTFLMAO
Sep 3, 2011 10:51 PM
tea-man
Dec 11, 2005 07:11 PM
rlaifatt
Nov 24, 2004 09:15 AM
