Catch can question
I do not recommend this set up if you are turbo'd because I think the vent hose is too small, you're better off venting it off to atmosphere. If you have to have a catch can get the ones designed for turbo applications.
What brand is that can? Please share. Where you buy?
Thanks!
Update: Searched Ebay and found this:
http://www.ebay.com/itm/Baffled-Alum...61085788361%26
1/2" ports. Maybe too big?
Thanks!
Originally Posted by jordannn93' timestamp='1361127659' post='22343644
My baffled catch can that was around $55 new
Thanks!
I forgot to mention, I'd strongly STRONGLY encourage you to use a supra PCV valve.
We tested the stock honda one against the supra one in my pic:
We put 10psi on the valve and submerged it under water and compared the bubbles. The honda unit blew a steady stream of bubbles. The supra unit only a few. I'll try to find the video we shot and upload to you tube.
Originally Posted by hvAlfaWant_S2000' timestamp='1361841492' post='22363333
^^ would I use the Supra pcv valve in lieu of the baffled can?
Thanks
Thanks
Thanks for the info.
