Catch Can WITH Valve Cover?
Old Apr 21, 2014 | 03:09 AM
johnsmith840's Avatar
Default Catch Can WITH Valve Cover?
Looking for a valve cover AND catch can setup for a turbo ap2. Basically a complete setup. The only thing I've been able to find that includes both (i am need a new valve cover) is this. https://www.s2ki.com/s2000/topic/953...ch-can-set-up/ Which I think would be perfect, but I dont think he's selling them anymore, the email came back undeliverable. Any suggestions/ideas as far as vendors/fabricators making/selling something like this? I have searched extensivly on google and the forums, and have found nothing. Other than needing a new valve cover because I have some problems with mine, I would like the complete kit because I am in Italy and currently do not have a fabricator to modify to the cover here. Thank you.
Old Apr 21, 2014 | 03:53 AM
Redline S2K's Avatar
Look into this catch can, you don't need to modify your valve cover.
http://www.radiumauto.com/Honda-C93.aspx
Old Apr 21, 2014 | 04:31 AM
Moddiction's Avatar
Former Sponsor
Just either buy a spare valve cover and drill/weld on the bungs or take your stock one off. Cheap to do. Then pick up a nice vented catch can setup. I sell some if interested and can even make custom pieces.
Old Apr 21, 2014 | 11:18 AM
Thank you both for the suggestions.
Old Apr 21, 2014 | 11:31 AM
Mr.60trim's Avatar
Just now seeing this. I may go this route
Old Apr 21, 2014 | 12:49 PM
CoolGuy094's Avatar
If you're putting an AP2 valve cover on it (AP1's can use 04-05 valve covers) you can just use the stock crankcase vent port and put on an -AN adapter to the PCV valve threaded port. That way you won't have to worry about welding on -AN bungs. Its not as sexy, and you're restricted by the size of those two existing ports, but its been enough venting for me at 16 PSI supercharged.
Old Apr 21, 2014 | 11:19 PM
It's a 2004 so I'll be getting a new AP2 cover. Sexy is not my concern, I just want it to function properly. So, delete the PCV Valve and run a single can set up off the PVC? That's what you have done Cool? I'm currently running 14LBS off a new GTX3076R but I will probably crank it to 16 or 18 (I need to retune and upgrade wastegate) so it doesnt grenade itself from running so low. I have a few issues to work out 1st though, this catch can setup is one of them.
I really like that setup from Radium, but it's a bit pricey IMO(if I were to go for the double can), then again, if I only have to run one can, it's not too bad, and like I said I don't have a trusted fabricator/welder here to modify the cover so this looks like a good option.
Old Apr 22, 2014 | 05:24 AM
Mr.60trim's Avatar
So for turbo setups, which catch can setup should one go with...crankcase, PCV, or both? For our cars Radium appears to have the option for each or both.
Old Apr 22, 2014 | 05:38 AM
02civic629's Avatar
^^^ This..... I just brought a spare vc, bungs, and ran 10an line to a catch can
Old Apr 22, 2014 | 05:55 AM
starrman's Avatar
I got my catch can from Moddiction...awesome piece, high quality and functions well. Looks good too.
